water pump gasket question #1019985
06/25/11 12:03 AM
06/25/11 12:03 AM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
i know this is simple, but what method are you guys using to install the water pump gasket? are you sticking it to the pump then mating it to the engine or sticking the gasket to the engine first?
reason i ask, is i managed to F up my first attempt by sticking it to the engine first. turns out it twisted on me when torquing the bolts down, ripped and leaked right off the bat.
thanks for the help guys
73 Road Runner 09 Challenger R/T
Re: water pump gasket question [Re: bigdaddywiz] #1019986
06/25/11 12:30 AM
06/25/11 12:30 AM
small or big block? Housing/timing cover to block or pump to housing/timing cover?
Re: water pump gasket question [Re: bigdaddywiz] #1019987
06/25/11 12:32 AM
06/25/11 12:32 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Form a gasket, avation formula, glued to the housing.
coat housing with form a gasket, smear a touch on the gasket, lay them on each other, then coat the engine side of the gasket and assemble.
Re: water pump gasket question [Re: sthemi] #1019988
06/25/11 12:43 AM
06/25/11 12:43 AM
Pittsburgh, PA
Pittsburgh, PA
thank you!
this is for a 318
Re: water pump gasket question [Re: bigdaddywiz] #1019989
06/25/11 08:45 AM
06/25/11 08:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive used 3M yellow trim adhesive for probally 30 years.I run a bot on the pump let it tack up and install.That way if you have to replace again most sticks to the pump and not the motor.Rocky
Chrysler Firepower
