Page 1 of 3 1 2 3
Six Pack Vacuum Secondary Spring Swap #1019759
06/24/11 05:05 PM
06/24/11 05:05 PM
State of Flux
Dodge Don Offline OP
State of Flux
Probably going to swap out my springs this weekend to address a WOT bog...I'm assuming it is fairly easy. Any advice?
I'll start with going one up in firmness from whatever springs are in there now. I'm assuming once I open them I'll find yellow ones.
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019760
06/24/11 05:26 PM
06/24/11 05:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the "plain"r steel looking ones are stock. I went with purples and they work great. Pretty easy just be careful so you don't tear anything.
Coming soon!!!!
Re: Six Pack Vacuum Secondary Spring Swap [Re: Mr.Yuck] #1019761
06/24/11 06:23 PM
06/24/11 06:23 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
agreed! the last thing you need is a hole in your rubber!
Re: Six Pack Vacuum Secondary Spring Swap [Re: Mr.Yuck] #1019762
06/24/11 06:32 PM
06/24/11 06:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
'69's came with purples. '70 up had yellows. i did some dragstrip test once and for every step up (stiffer) the car went about a tenth slower in the 1/4 mile. this was with a near stock 69 coronet, 3.23 gear, torqueflite. my car gave the best e.t. with yellows. purples will give a little more torque. plain springs went almost 3 tenths slower than yellows. if you have a serious bog i'd look at float level too low, main jetting and idle circuts too lean, low fuel pressure, or lazy timing. stiff springs may only mask another problem. there is a 6-pak tune-up presentation that often is tossed into the suggestions when tune-up questions are asked on moparts. beware, its pure garbage!
Re: Six Pack Vacuum Secondary Spring Swap [Re: lewtot184] #1019763
06/24/11 06:36 PM
06/24/11 06:36 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
And check the accelerator pump for sure.
Re: Six Pack Vacuum Secondary Spring Swap [Re: FJ5_Fish] #1019764
06/24/11 08:39 PM
06/24/11 08:39 PM
State of Flux
State of Flux
Well that was a surprise, my springs are Black. So no going up from that.
Carbs are still pretty new....original carbs rebuilt and restored by Promax including their metering block and billet plates.
I just had the engine re-timed (no idea the setting right now) and before I could light it up good. Now a momentary bog on WOT so I thought it might be the springs. Car runs great now except for bog. Maybe I should move my distributor a hair? Which way ?
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019765
06/24/11 08:43 PM
06/24/11 08:43 PM
on the bottom side hold the rod "up" just the right amt so the black neoprene gasket stays level/flush w the housing & does not cave into the recess as you set the spring/cover down onto it & maintain that tension as a HELPER SCREWS IN THE SCREWS
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019766
06/24/11 10:40 PM
06/24/11 10:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Stock set-up springs are black, toss in the whites, work up from there if the tip-in RPM is too soon for you,...BBlk 440/6's like lots of initial advance, so start at 10-12 BTDC, and bump it up till she'll take no more before running hot/pinging/starter kick back,...what the total advance curve?/RPM that it's all in?...
double check that when you change the springs that the diaphram's indexed properly, it has a vacumm passage in it's perimeter, easy to block/distort it, test the pod later to see if a vacumm source will pull it open, to confirm function
Re: Six Pack Vacuum Secondary Spring Swap [Re: DAYCLONA] #1019767
06/25/11 09:00 AM
06/25/11 09:00 AM
State of Flux
State of Flux
If it bogs with black springs why would I go down to a lighter spring? Wouldn't that just make it worse?
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019768
06/25/11 09:31 AM
06/25/11 09:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your bog might just be the opposite of a sixpack that opens too soon,....the black spring is so stiff the time delay (bog) is in the secondary pods opening so slowly,.....I've done the spring swaps so many times on my cars, and customers, playing with the spring color change graduations, spring after spring, only to find that I usually end up with the white springs,....so i just start right off the bat with them,......I personally like to see the carbs come in at 2500-3000 RPM, basically on command with the "loud pedal", rather than wait for them with a higher "vacumm"(stiffer) rated spring,......your bog may also be related to your ignition, depending on the type of advance, and how much, and when, if it's in/out of sync with the RPM opening of the end carbs,....alot going on, you have to time it all right, otherwise the car falls on it's face
Mike
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019769
06/25/11 10:44 AM
06/25/11 10:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
black springs are too heavy. i think your problem is something other than opening rate. check the float level and fuel pressure. if your using an aftermarket vapor seperator the return hole is too big reducing fuel pressure. check the distributor to make sure the centrifugal advance is working. were any mods or aftermarket parts added to the carbs? intake manifold leaking? i've got an edelbrock ch6 on one of my cars that had a hole in it, (casting flaw)!
Re: Six Pack Vacuum Secondary Spring Swap [Re: lewtot184] #1019770
06/25/11 11:47 AM
06/25/11 11:47 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I gotta hand it to you guys that are trying to help the OP. With the info given, I have no idea on even where to begin.
Lew is probably right: black spring and a WOT bog (I'm presuming he actually means a hesitatation), the problem is elsewhere.
Re: Six Pack Vacuum Secondary Spring Swap [Re: BSB67] #1019771
06/25/11 01:19 PM
06/25/11 01:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
just thinking here, why would a professional carb shop put black springs in the diaphragms? using black or brown springs was something thats done when the kill bleeds are blocked. blocking the kill bleeds brings the end carbs in rapidly and heavier springs are installed to compensate for it. if you have a cold intake the problem gets worse. you don't state the engine build, what is it? i think some of the aftermarket parts are more gadjet than necessary. i have two six pak cars that drive beautifully and i've never seen a reason for the gadjets. i've been playing with the six-paks since 1970 and for all practical purposes they just don't need to be re-engineered.
Re: Six Pack Vacuum Secondary Spring Swap [Re: lewtot184] #1019772
06/25/11 05:31 PM
06/25/11 05:31 PM
State of Flux
State of Flux
440 bored 30 over. Speedpro 2355 pistons, Eddy heads, 528 solid lifter cam w/ 1.6:1 iron inductile rockers, HP mech. fuel pump, 3/8 fuel line, factory vapour seperator, auto with Turbo Action converter and shift kit, 3.91:1 suregrip.
Just took car out again. From a standing start I can smoke the tires at will, no hesitation, no bog.
From a rolling start and going WOT it either usually hesitates for about a second or less and then throws you back in your seat...on a few occasions it will stumble until I take my foot off it.
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019773
06/25/11 05:50 PM
06/25/11 05:50 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Don - I would start with the timing and then the accelerator pump adjustment. Are you running a vacuum advance?
Re: Six Pack Vacuum Secondary Spring Swap [Re: lewtot184] #1019774
06/25/11 07:26 PM
06/25/11 07:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Couldn't have said it better.Here are the last three sets I did a few months back,if you would have seen how they were screwed up and some of the so called modification it would boggle your mind.I to have been doing them since the early 70's and could probably write a book.
Re: Six Pack Vacuum Secondary Spring Swap [Re: 62maxwgn] #1019775
06/25/11 08:55 PM
06/25/11 08:55 PM
State of Flux
State of Flux
I just swapped the black springs for purple and I'll test it out tomorrow to see what happens.
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019776
06/25/11 09:10 PM
06/25/11 09:10 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your using the high pressure carter fuel pump check the pressure. they're usually around 8.5-9 psi. the aftermarket vapor seperator will reduce pressure some due to the large return orfice. you might be o.k. but i'd check anyway. do you know how to check and see if the kill bleeds are blocked?
Re: Six Pack Vacuum Secondary Spring Swap [Re: lewtot184] #1019777
06/25/11 09:34 PM
06/25/11 09:34 PM
State of Flux
State of Flux
no I do not.
Re: Six Pack Vacuum Secondary Spring Swap [Re: Dodge Don] #1019778
06/25/11 10:43 PM
06/25/11 10:43 PM
PNW
Danan Offline
Danan  Offline
PNW
1. What is your lowest vacuum reading at idle and cruise?
2. What power valve do you have?
3. What jets do you have in the center and outboard carbs?
4. Do you have an Air/Fuel meter? If so, what is your A/F reading at idle/cruise/WOT? If not, get one!
5. You need to find out where your initial timing is, and what your total (initial and mechanical) timing is.
6. How much of the transfer slot is exposed on the center carb? Oftentimes with a big cam and messed up jetting you end up cranking the idle speed screw WAY in to compensate for everything else that is out of whack. At that point, you are IDLING on the CRUISE circuit, which typically results in flat off-idle acceleration in my experience.
7. For a baseline, I would install the stock (unpainted, in my experience) springs in the secondary carbs and then get everything else right (timing/jetting) before you start messing with springs.
With the above info, you will get much better advice. As it is, everyone is sort of shooting from the hip when they make suggestions. Don't take it like I'm bagging on you, because I'm not. We're all here to help you enjoy your car. Six packs are the quintessential musclecar induction system; you shouldn't have to deal with bogs/poor performance.
But first you need to figure out what's going on with your engine/ignition so you can give the car what it wants/needs.
Page 1 of 3 1 2 3
