Re: Harland Sharp rockers and pushrods question [Re: Bigbeep] #1019724
06/29/11 12:01 PM
06/29/11 12:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
the ball end of them was grinding off in the lifter cup. After looking at the roller lifter a little closer, I noticed the cup looked like it was too small for a 3/8" ball end. It was.
When I was checking my Indy pushrods in the lifters they didn't sit right. I coated the tip with a magic marker then fit it into the lifter and it showed a ring where it was only making contact with the edge of the cup. ???! So then I checked the ball and cup with radius gauges. The cups were 3/8" dia. but the "supposedly" 3/8" dia. pushrod tips were off. Indy has them back and I've ordered Smiths.
FWIW, Smiths pushrods come in .050" increments which is one thread of an adjuster screw.
Re: Harland Sharp rockers and pushrods question [Re: 426keith] #1019725
06/29/11 01:05 PM
06/29/11 01:05 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
Just some info on the HS rockers...They use a 5/16" ball adjuster so if your pushrods have a 3/8" cup they need to be replaced anyway.
Re: Harland Sharp rockers and pushrods question [Re: hankcrank] #1019726
06/29/11 02:45 PM
06/29/11 02:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Or use your Indy adjusters in the HS rockers! Same thread.
Re: Harland Sharp rockers and pushrods question [Re: Stanton] #1019727
06/29/11 03:11 PM
06/29/11 03:11 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Smith bros will make you any custom length as well and you will still have them at your door in a few days.
Re: Harland Sharp rockers and pushrods question [Re: Stanton] #1019728
06/29/11 03:59 PM
06/29/11 03:59 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Mine weren't - Indy 3/8" vs HS 7/16"
Re: Harland Sharp rockers and pushrods question [Re: PorkyPig] #1019729
07/02/11 01:16 PM
07/02/11 01:16 PM
Mo.
racerx Offline
racerx  Offline
Mo.
anymore helpful info?
