Spring on E-brake Pedal #1019629
06/24/11 02:08 PM
06/24/11 02:08 PM
Western Pa
joewhite440 Offline OP
Western Pa
Does the 1970 Challenger E Brake Pedal have a return spring like on the 1973. I do not see any whole for it. If not what pulls it back up when you release it?
Joe
Re: Spring on E-brake Pedal [Re: joewhite440] #1019630
06/24/11 06:51 PM
06/24/11 06:51 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Joe
The spring design and location are different in 70 than in 73
Re: Spring on E-brake Pedal [Re: Morty426] #1019631
06/24/11 08:04 PM
06/24/11 08:04 PM
Western Pa
Western Pa
Do you have anything that shows me that? Picture, Diagrams. Drawings. I have both Pedals. The 70 does not have the spring and I do not see any holes where it would go. I used the little catch release spring off the 73 on the 70. It was the same.
Re: Spring on E-brake Pedal [Re: joewhite440] #1019632
06/24/11 08:10 PM
06/24/11 08:10 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Re: Spring on E-brake Pedal [Re: johnscudashop] #1019633
06/24/11 08:25 PM
06/24/11 08:25 PM
Western Pa
Western Pa
Any and all help and comments appreciated!!!
Joe
Re: Spring on E-brake Pedal [Re: joewhite440] #1019634
06/30/11 10:59 PM
06/30/11 10:59 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
A factory service manual (FSM) probably would.
Re: Spring on E-brake Pedal [Re: In_The_Pink] #1019635
07/01/11 09:15 AM
07/01/11 09:15 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
There is no return spring on a 70 E brake.
The cable tension returns the pedal to its'
resting position.
Jules
Re: Spring on E-brake Pedal [Re: JulesdaWiperman] #1019636
07/01/11 07:55 PM
07/01/11 07:55 PM
Western Pa
Western Pa
Once again, Thank you very much Jules!
Joe
Re: Spring on E-brake Pedal [Re: joewhite440] #1019637
07/11/11 07:19 PM
07/11/11 07:19 PM
Western Pa
Western Pa
Jules and all others. Is there a bracket that bolts on it to hold the cable? I have the pin to hook the cable to the pedal. My assembly looks just like the one pictured but not as nice. I see two wholes there where it may mount?
Thank you all!
Re: Spring on E-brake Pedal [Re: joewhite440] #1019638
07/12/11 08:41 AM
07/12/11 08:41 AM
super gas
super gas
Yes . It is a U type bracket and a bolt w/nut.
see pic.
