fuel/brake line replacement #1019585
06/24/11 12:08 PM
06/24/11 12:08 PM
Long Island, NY
shakerjoe Offline OP
Long Island, NY
what are the best aftermarket lines right now to replace oe lines - think the concencus has been Fine Lines - might order to pick up in Carlisle to try avoid bends during shipping - thanks in advance - Joe
Re: fuel/brake line replacement [Re: shakerjoe] #1019586
06/24/11 12:17 PM
06/24/11 12:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Fine Lines.
Talk to Randy at Dixie Restoration parts ,he's cheaper than going direct
Re: fuel/brake line replacement [Re: shakerjoe] #1019587
06/24/11 12:20 PM
06/24/11 12:20 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I'm in the process of installing a kit from inline tube on my Challenger. So far it looks to fit real good and the kit looks like nice quality. I got my kit in stainless steel.
Re: fuel/brake line replacement [Re: gtx6970] #1019588
06/24/11 03:11 PM
06/24/11 03:11 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Fine Lines.
with Bill...
Re: fuel/brake line replacement [Re: rayztoy] #1019589
06/24/11 03:31 PM
06/24/11 03:31 PM
Long Island, NY
Long Island, NY
good to know - will give Randy a
Re: fuel/brake line replacement [Re: rayztoy] #1019590
06/24/11 05:19 PM
06/24/11 05:19 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Fine Lines.
with Bill...
with Rayztoy
Troy
Houston Mopar Connection Club
Re: fuel/brake line replacement [Re: hemi68charger] #1019591
06/24/11 07:52 PM
06/24/11 07:52 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I went with The Right Stuff and have been very happy. Several local guys had leaks with Fine Line's. They all switched to The Right Stuff and no more leaks.
1968 Plymouth Road Runner 383 4 speed
Re: fuel/brake line replacement [Re: dobie] #1019592
06/24/11 08:42 PM
06/24/11 08:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That is Fine lines lines don't leak. I have done 2 cars with them and actually drive them now for over 5 years and more on my 74. I have made plenty of steel lines, it is not hard to make a good line with a good double flaring tool. So it really don't matter who makes the ends, they all should be the same, it's the bends that might be different between suppliers.
Many things cause leaks, usally caused by the installer.
Re: fuel/brake line replacement [Re: shakerjoe] #1019593
06/24/11 10:54 PM
06/24/11 10:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Fine lines and Right Stuff are both great products, I've used both, although i prefer Fine lines stainless steel lines, better selection/coverage on various models as equipped
I find that most people that have problems with steel or stainless lines leaking, the root cause is usually due to IE (installation error)
Re: fuel/brake line replacement [Re: Challenger 1] #1019594
06/25/11 12:43 AM
06/25/11 12:43 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Yeah, probably. Just giving my observations from my limited personal experience.
