Length and size of bolts and studs on 71 Air Grabber #1019294
06/23/11 05:21 PM
06/23/11 05:21 PM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
I need to know what size and length the studs and nuts are for a 71 charger air grabber hood. All my studs on the hood and snapped and i have no nuts. Pictures would be great if anyone has any...
Thanks,
Steve
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019295
06/23/11 05:29 PM
06/23/11 05:29 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
and i have no nuts.
Thanks,
Steve
Steve,
That's so sad.
Re: Length and size of bolts and studs on 71 Air Grabber [Re: Morty426] #1019296
06/23/11 07:06 PM
06/23/11 07:06 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
and i have no nuts.
Thanks,
Steve
Steve,
That's so sad.
So you are married then.
Re: Length and size of bolts and studs on 71 Air Grabber [Re: FJ5_Fish] #1019297
06/23/11 07:09 PM
06/23/11 07:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
and i have no nuts.
Thanks,
Steve
Steve,
That's so sad.
I was going to ask if he checked her purse
Re: Length and size of bolts and studs on 71 Air Grabber [Re: Morty426] #1019298
06/23/11 07:43 PM
06/23/11 07:43 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Al Wilson makes the studs. Can probably pick some up at Cailsle. They are a special really hard to find stud.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Length and size of bolts and studs on 71 Air Grabber [Re: moparmarks] #1019299
06/23/11 09:32 PM
06/23/11 09:32 PM
Millersville, PA
Millersville, PA
Thanks mark, do you know if he makes the nuts? Does anyone have any pictures?
Please respond only if its relative to my question
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019300
06/23/11 10:17 PM
06/23/11 10:17 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Hey - Let's stick to the topic!
Sorry, couldn't resist. If I knew the answer I would of answered intelligently....instead
Re: Length and size of bolts and studs on 71 Air Grabber [Re: FJ5_Fish] #1019301
06/23/11 11:07 PM
06/23/11 11:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Same here.
I can get you 70 but I'm sorry I don't know about 71
Re: Length and size of bolts and studs on 71 Air Grabber [Re: Morty426] #1019302
06/23/11 11:55 PM
06/23/11 11:55 PM
moparmarks Offline
moparmarks  Offline
Heres a link to he site. Don't think he has the nuts but might know who does.
http://www.n96airgrabber.com/products.asp?cat=10
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019303
06/24/11 09:30 AM
06/24/11 09:30 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
If they are the same as 1970 Plymouth. they are a 10-24 machine thread. And are NOT avail.
They look like this only black phosphate.
Re: Length and size of bolts and studs on 71 Air Grabber [Re: gtx6970] #1019304
06/24/11 03:59 PM
06/24/11 03:59 PM
Millersville, PA
Millersville, PA
Those studs do not appear correct to me, maybe we are talking different studs, i am talking about the ones on this part...
http://cgi.ebay.com/ebaymotors/70-Roadru...=item20b14bfa3e
I need the size of those and the nuts that go on it...
Thanks,
Steve
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019305
06/24/11 06:26 PM
06/24/11 06:26 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
If you are talking about the Bell Nuts Frank Badalson has them......ask him about the studs as well.
Here is the parts book diagram
Re: Length and size of bolts and studs on 71 Air Grabber [Re: FJ5_Fish] #1019306
06/25/11 09:40 AM
06/25/11 09:40 AM
Millersville, PA
Millersville, PA
Bell nuts? I thought they were for the super bee insert? I have never had an air grabber setup so i could be wrong...
What i am trying to find is the STUDS and NUTS that hold the airbox to the hood? I have nothing to verify anything against so any pics or info is helpful!
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019307
06/25/11 10:27 AM
06/25/11 10:27 AM
moparmarks Offline
moparmarks  Offline
I'm not sure on the Ramcharger setup. Do the studs thread into metal? The ones that Al has thread into plastic and are used on the Ply A/G, 71/2RR and 71Bee/Charger hood inserts. The corner studs use a bell net.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Length and size of bolts and studs on 71 Air Grabber [Re: moparmarks] #1019308
06/25/11 10:59 AM
06/25/11 10:59 AM
Millersville, PA
Millersville, PA
They are the studs that are welded to the brace on the backside (just like the studs on a rad support that have a circular backing on them).
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019309
06/25/11 01:14 PM
06/25/11 01:14 PM
moparmarks Offline
moparmarks  Offline
Oooooooooooh, well never mind. Wrong stud.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Length and size of bolts and studs on 71 Air Grabber [Re: HemiChallenger] #1019310
06/28/11 01:22 AM
06/28/11 01:22 AM
Chilly Northern, Minn.
71 Charger R/T Offline
I've got a Ramcharger hood out in the garage, I'll try to get you some pictures.
Re: Length and size of bolts and studs on 71 Air Grabber [Re: 71 Charger R/T] #1019311
07/01/11 11:15 AM
07/01/11 11:15 AM
Steve, Here's a picture or two of the original style nut (3/8"). It appears that the ones Bill Allphin (GTX6970) has posted are the correct nuts.....
The studs as you said are like the ones on the core support (round head) I think your best bet for those would be to grind the top of a hex head to about half its thickness, put it through the hole and tack weld it on the backside. No one will see that once the hood frame is back in place.
Hope this helps! Your story has been an encouragement to me and helped motivate me to get my car done. my story
Re: Length and size of bolts and studs on 71 Air Grabber [Re: 71 Charger R/T] #1019312
07/02/11 01:09 PM
07/02/11 01:09 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Did you check the AMK prod web site?? You could probally find something very close from them and there web site has color pics as well.
