Holley is puking fuel #1018834
06/23/11 08:53 AM
06/23/11 08:53 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Friend of mine has a problem with his 4160. He has never started the car, he says he has spark, but the fuel is puking from the vents on both sides. I haven't personally touched the adjustment, but it sounds like his floats are sticking or just not adjusted correctly. Been a while since my hands have worked on a Holley but I am more mechanically inclined than he is...What should I mess with first?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Holley is puking fuel [Re: Pyper70] #1018835
06/23/11 08:59 AM
06/23/11 08:59 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
What's his fuel pressure? Trash in the carb, Yes check the floats.
Re: Holley is puking fuel [Re: ireland383] #1018836
06/23/11 09:06 AM
06/23/11 09:06 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
he doesnt have a gauge hooked up for his pressure but if it gushes out then thats a plus right?...plus as meaning the pump is still doing its job.
He said he has rebuilt it once himself...and once to a goober who swore he knew what he was doing.
Re: Holley is puking fuel [Re: Pyper70] #1018837
06/23/11 09:14 AM
06/23/11 09:14 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
It is important that his pressure is not above 7, 6.5 would be better. Chances are is floats are way high. Lower them to a point where fuel is just below the the port holes on the side.
Re: Holley is puking fuel [Re: DANA60] #1018838
06/23/11 10:46 AM
06/23/11 10:46 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
he has a stock fuel pump...I told him way back when to get the clear sights for the bowls so he can get a better view of where he has to adjust the float to...
Re: Holley is puking fuel [Re: Pyper70] #1018839
06/23/11 10:51 AM
06/23/11 10:51 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
They might just be hung up, or the spring or seat is bad. He might want to take it apart to check.
Re: Holley is puking fuel [Re: Pyper70] #1018840
06/23/11 10:52 AM
06/23/11 10:52 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
careful with holley clear plastic sights,finger tight only,and at least for me,i don't leave in,they seem to almost dissolve
Re: Holley is puking fuel [Re: meepmeep70] #1018841
06/23/11 11:58 AM
06/23/11 11:58 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Those clear plastic plugs are a joke, they crack,break apart & fog up so they become impossible to see through.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley is puking fuel [Re: joedust451] #1018842
06/23/11 12:07 PM
06/23/11 12:07 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you dont have to take the site plugs allthe way out just loosen them up till their wobbly if gas comes out screw them back in and adjust the float down then do it again till no gas seeps out.now you can remove it and make your adj. without a big mess.but as was said i would check needle and seat first if its been sittin.and remember clockwize lowers counter raises your fuel level.(thats the one i always forget).
Re: Holley is puking fuel [Re: bonefish] #1018843
06/23/11 01:11 PM
06/23/11 01:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And when you get the carb sorted out change the oil....
Re: Holley is puking fuel [Re: DANA60] #1018844
06/23/11 01:22 PM
06/23/11 01:22 PM
dogdays Offline
dogdays  Offline
I set the fuel level with the engine running and plugs out. When I find the point where fuel just dribbles out, I know I'm there. Sometimes I adjust the float down or up to make small A/F ratio changes. That is especially helpful on a 4160 with its secondary metering plate that doesn't have jets.
R.
Re: Holley is puking fuel [Re: dogdays] #1018845
06/23/11 01:38 PM
06/23/11 01:38 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Sounds good guys...I'll pop by this weekend and see what I can do for him.
Re: Holley is puking fuel [Re: Pyper70] #1018846
06/23/11 01:59 PM
06/23/11 01:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd check the floats first
Coming soon!!!!
Re: Holley is puking fuel [Re: Mr.Yuck] #1018847
06/23/11 02:11 PM
06/23/11 02:11 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
The easiest way is get a rag & stuff it on the side of the site plugs, then take them out & adjust, on a 4160 with the metering plate it helps if you adj. the rear a bit higher then the front.
Re: Holley is puking fuel [Re: Mr.Yuck] #1018848
06/23/11 02:23 PM
06/23/11 02:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
......chances are the float level is too high and the carb is experiencing "fuel pull over" while running ....when it's running, if it can, look down the throat/bores, see if you see fuel being pulled over/around the annuals/ venturis,...if so, lower the fuel level until it stops
Re: Holley is puking fuel [Re: DAYCLONA] #1018849
06/23/11 02:59 PM
06/23/11 02:59 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Sunk float too. If you pull the needle and seat assemblies, take something to push down lightly on the float tab to see if it has some resistance, meaning it's buoyant. If it's not resisting it may have been saturated or full of fuel and not working properly. Pretty common with brass floats that are old.
