big block dual exhaust hanger question #1018810
06/23/11 12:51 AM
06/23/11 12:51 AM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
Ive removed the 7 1/4 rear, my springs, shocks, etc on my 69 charger, the car is a 318 car, when I install the 440 with the dual exhaust, where do the hangers bolt up? are the mounts for the hangers for the single exhaust from the small block correct for the rs for the BB? or do I need to intall different mounts on the the frame/body on both sides? is there a source for these?
Duane
ps any pics would help.
Re: big block dual exhaust hanger question [Re: 69Chrgr] #1018811
06/23/11 08:29 AM
06/23/11 08:29 AM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
actually found it from year one, dont know if anyone sells it for a better price (39.95) has anyone installed these? does it mirror the rs bracket where it gets mounted?
Duane
Re: big block dual exhaust hanger question [Re: 69Chrgr] #1018812
06/23/11 08:35 AM
06/23/11 08:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: big block dual exhaust hanger question [Re: 69Chrgr] #1018813
06/23/11 09:42 AM
06/23/11 09:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Duane
Look closely at the floor on the right side and you should see 4 dimples , that's where you drill your holes .
Re: big block dual exhaust hanger question [Re: gtx6970] #1018814
06/25/11 06:17 AM
06/25/11 06:17 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
http://www.accurateltd.com/B-Body-Hangers_c_95.html
ok....do you have all the hangers for a '68 Hemi roadrunner exhaust?
I used the YearOne mounts and they broke right away. The rubber couldn't take the weight of the exhaust.
