Need electrical help in Detroit area #101873
08/09/08 02:47 PM
08/09/08 02:47 PM
Anonymous OP
Anonymous OP
Help...just finished my 70 hemi cuda for the dream cruise next week in detroit and have an electrical issue (think its a short in my charging system) that i just cant figure out. Any references in the detroit metro area? Any help would be appreciated.
Rob
rcola427@aol.com
Re: Need electrical help in Detroit area #101874
08/09/08 02:59 PM
08/09/08 02:59 PM
The Thumb O' Michigan
Fluffy Offline
Automotive STD Guy
Fluffy  Offline
Automotive STD Guy
Which part of the Detroit area will you be in?
Re: Need electrical help in Detroit area [Re: Fluffy] #101875
08/09/08 09:16 PM
08/09/08 09:16 PM
Anonymous OP
Anonymous OP
south lyon - about 15 min from ann arbor, but i can drive to where ever...
Re: Need electrical help in Detroit area #101876
08/09/08 10:48 PM
08/09/08 10:48 PM
Fluffy Offline
Automotive STD Guy
Fluffy  Offline
Automotive STD Guy
I went to a small, small shop in Sterling Heights. It's just South of Hall Rd. on Van Dyke. I can't think of the name off hand, maybe Wile1 will chime in.
He recommended the shop and they found my electrical issue(which I couldn't find) within a couple hours.
Re: Need electrical help in Detroit area #101877
08/10/08 11:36 AM
08/10/08 11:36 AM
michigan
black64 Offline
black64  Offline
michigan
Can you describe the electrical issue you have?
Re: Need electrical help in Detroit area [Re: black64] #101878
08/10/08 09:10 PM
08/10/08 09:10 PM
Anonymous OP
Anonymous OP
only charging at 11.7-12 volts - everything is new including the alternator, vr, ballast and battery - twice. Think its a short, but cant find it...
Re: Need electrical help in Detroit area #101879
08/10/08 10:32 PM
08/10/08 10:32 PM
at a fast idle jump from large alt stud to alt field terminal for (2) seconds & see if the charge rate goes sky high.this is "full fielding" the alt to see if it's functioning. See if VR is grounded good. key on eng off see if both VR terminals read battery voltage(or close to it). Holler back.
Re: Need electrical help in Detroit area [Re: RapidRobert] #101880
08/11/08 10:36 AM
08/11/08 10:36 AM
michigan
black64 Offline
black64  Offline
michigan
Good test to run because you have no output from the alt. You are running off of the battery with reading of 11.7 - 12.0 volts.
Re: Need electrical help in Detroit area #101881
08/11/08 11:16 AM
08/11/08 11:16 AM
michigan
64ssmax Offline
64ssmax  Offline
michigan
Rob
rcola427@aol.com
http://www.jakesautomotive.com/
call and ask for Gary!
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
