06 3.5L noise?? #1018745
06/22/11 10:49 PM
06/22/11 10:49 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Just picked up a noise in the 300. It's almost like a knock but with a rattle to it. It's not a clearly defined one shot noise, more drawn out. I've only heard it at an idle, got home tonight and heard it when I pulled in the garage. Seems to have a frequency of just over a second, but didn't actually time it. Broke out the stethoscope and couldn't hear anything unusual anywhere I could reach with the probe, but the stethoscope quit working before I played too long. Seems to be most audible when I get my ear down near the right front gap under the intake but I'm not positive it's not reflecting from there. Any ideas on where to start?
Oh, does anyone have a picture of the head with the valve covers off?
Thanks,
Mike
Re: 06 3.5L noise?? [Re: 1E2C] #1018746
06/22/11 11:55 PM
06/22/11 11:55 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Those late model 3.5 are notorious for the dowel pins that hold the exhaust rocker shafts in posistion to break and allow the rocker shafts to turn and not allow oil to ger to the lash adjusters in the rocker arms. Pull the valve covers and look at the notches in the end of the rocker shafts. They should be facing straight up. The notches are at the front on the drivers side and at the rear on the passengers side. Mopar now sells the rockers, shafts, and stands as a pre-assembled package.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 06 3.5L noise?? [Re: 71yelladustr] #1018747
06/23/11 01:57 PM
06/23/11 01:57 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
The shaft pins are not the only thing to look for, I have seen several lately that have worn the rocker into the holddown and make similar noise, this set is off of a 16,000 mile one.
You are pulling the valve covers either way, pay attention to the rocker to holddown, in the picture the left side of the holddown is fine, obviously the right is not.
As was stated they come as assemblys but beware you can still get indivdual pieces....you DO NOT want to screw with it, removing the pins in itself is a disaster waiting to happen.
Rick
Re: 06 3.5L noise?? [Re: Blown71X] #1018748
06/23/11 11:31 PM
06/23/11 11:31 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Well, you guys had me worried, but rocker issues was my biggest fear to start with. Anyway, in accordance with the KISS (keep it simple, stupid) theory I did start with the basics when I got a chance to play tonight. Pulled the serpentine belt and fired it up, the noise is gone. Neither idler nor the tensioner seemed very bad, but it appears one of them is the issue. Lots cheaper and easier, need to get some parts tomorrow.
Thanks all,
Mike
