aluminum radiator and fan for A body #1018718
06/22/11 10:24 PM
06/22/11 10:24 PM
White House,TN
stroked470 Offline OP
White House,TN
I know I seen it posted but cant find it now. What size aluminum radiator and what fan is everyone running on there A body. I was thinking someone was running a 31x19 but dont remember exactly. I need to get one for my 68 Valiant but haven't been over to measure for it yet.
Re: aluminum radiator and fan for A body [Re: stroked470] #1018719
06/22/11 10:38 PM
06/22/11 10:38 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I am runnig a summit 27.5x19 rad with a 3.8 ford trous(spelling) fan on my 73 big block dart. but a lot of guys are useing the fan off a HHR chevy. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: aluminum radiator and fan for A body [Re: mopar65] #1018720
06/22/11 10:46 PM
06/22/11 10:46 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I have been back and forth to Summit the past couple of days. started with a 26". had plenty of room. ended up with a 28x19 triple pass radiator.
Re: aluminum radiator and fan for A body [Re: mopar65] #1018721
06/22/11 10:47 PM
06/22/11 10:47 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
Got a pic? What is the radiator opening size?
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: aluminum radiator and fan for A body [Re: dart440_72] #1018722
06/22/11 10:49 PM
06/22/11 10:49 PM
White House,TN
White House,TN
I had another 68 several years ago that was just a race car also, I used a 31x19 on it but I had to do alot of cutting from what I remember. I am wanting to street this one.
Re: aluminum radiator and fan for A body [Re: stroked470] #1018723
06/22/11 10:50 PM
06/22/11 10:50 PM
White House,TN
White House,TN
I have not measured the opening but I am guessing it is 25-26 inches. I know it is bigger then the 22 inch opening my old 69 Satelite had.
Re: aluminum radiator and fan for A body [Re: stroked470] #1018724
06/22/11 10:55 PM
06/22/11 10:55 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
31x19 double pass in car below. had to notch the frame rails and i opened up he rad opening
Re: aluminum radiator and fan for A body [Re: stroked470] #1018725
06/22/11 10:57 PM
06/22/11 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just got my Summit 19 X 31 triple pass radiator
today... I dont have a core support to worry about...
this is going into my Rampage
Re: aluminum radiator and fan for A body [Re: stroked470] #1018726
06/22/11 11:06 PM
06/22/11 11:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I run a 31" x 19" Howe in a 73 Sport A body. I did have to pocket out the passenger side frame rail.
The newer triple pass rads may be a better option as they will cool better by using more of the surface area of the rad. But for street use, bigger is almost always better.
Between the stock rails 29",s is about the limit.
Re: aluminum radiator and fan for A body [Re: stroked470] #1018727
06/22/11 11:10 PM
06/22/11 11:10 PM
Australia
Charger VJ RB Offline
Australia
Make sure it does not get to wide and get too close to the battery tray and battery (depending on which side you have the filler neck on) I went back to a 26 x 19 howe rad, if your battery is in the boot then a 28 x 19 should fit easy. If you do some notching of the lip on the frame rails you will get a 31 x 19 but that is in a 72 dart which is 1 inch wider than a 68 yes? so maybe 30 inch wide max, wheres that tape
RB XE274H Q-850
Re: aluminum radiator and fan for A body [Re: Charger VJ RB] #1018728
06/22/11 11:14 PM
06/22/11 11:14 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
champion rad. very good prices and work well. brad
Re: aluminum radiator and fan for A body [Re: a493demon] #1018729
06/23/11 03:38 AM
06/23/11 03:38 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Be Cool, with dual fans
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: aluminum radiator and fan for A body [Re: BloFish] #1018730
06/23/11 10:55 AM
06/23/11 10:55 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Hey guys how thick are the 28x19 triple pass radiator?
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: aluminum radiator and fan for A body [Re: megajoltman] #1018731
06/23/11 09:11 PM
06/23/11 09:11 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I got a Champion for my Dart. Fits stock opening. Have a pusher fan on the front.
Re: aluminum radiator and fan for A body [Re: 70HemiGTX] #1018732
06/23/11 10:56 PM
06/23/11 10:56 PM
indiana
moparbrown14 Offline
indiana
google smith radiator you will like the quality
Re: aluminum radiator and fan for A body [Re: moparbrown14] #1018733
06/24/11 12:01 AM
06/24/11 12:01 AM
IN
ahy Offline
ahy  Offline
IN
The 26" Mancini "Muscle Car" downflow aluminum radiator, matching shroud and thermal fan clutch has worked well for me. 496B with AC.
Re: aluminum radiator and fan for A body [Re: megajoltman] #1018734
06/24/11 12:04 AM
06/24/11 12:04 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
They are 3 times as thick!
No reason for them not to be about the same thickness as normal rads.
If I need to buy again ,it will be a triple pass.
Re: aluminum radiator and fan for A body [Re: moparbrown14] #1018735
06/24/11 12:32 AM
06/24/11 12:32 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
thats what i run
here it is compared to my junk be-cool
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: aluminum radiator and fan for A body [Re: megajoltman] #1018736
06/24/11 12:36 AM
06/24/11 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
2.25"... I just sent my 19.625" X 31" triple back for a
19" X 28" triple... I didnt like how I had to fit the
bigger one because of the height
Re: aluminum radiator and fan for A body [Re: Sport440] #1018737
06/24/11 12:39 AM
06/24/11 12:39 AM
megajoltman Offline
megajoltman  Offline
I had heard the tank and core was thicker
Procharged 350Z
