'68 Coronet died & won't start, electrical issue #1018615
06/22/11 08:19 PM
06/22/11 08:19 PM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
While driving near my house the other day, my '68 Coronet just cut out and died. It cranks fast, a few cylinders fire, but it won't start. It acts like it wants to start, but the ignition system can't sustain it.
I replaced the coil and voltage regulator with ones known to be good, but no change. With the key in the "ON" position, I measure no voltage at the coil. Did my 6AL box quit?
Re: '68 Coronet died & won't start, electrical issue [Re: 68red440] #1018616
06/22/11 09:40 PM
06/22/11 09:40 PM
that'd b my guess. W MSD do 2 wires go to the batt positive/neg and 2 wires go to the coil positive/neg? I would think the coil pri should b hot in ign1 (& 2) but the MSD is not grounding the pri neg side to trigger a spark. Not absolutely sure as I am not an MSD afficionado. Have an ECU/ballast & some jumper wires you can sub in real quick? Otherwise here's a BTT for you
Re: '68 Coronet died & won't start, electrical issue [Re: RapidRobert] #1018617
06/22/11 10:10 PM
06/22/11 10:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just for the heck of it try wiggling the wires at the bulkhead connector. I have had bad connections there cause a no run problem.
Re: '68 Coronet died & won't start, electrical issue [Re: 68red440] #1018618
06/22/11 10:10 PM
06/22/11 10:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most MSD Ive seen fail you have nothing.Do you still have the ballast hooked up?MSD has a trouble shooting guide on their web site.Rocky
Chrysler Firepower
