wiring a 3 wire denso
#1018590
06/22/11 07:40 PM
06/22/11 07:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have just fitted a 130 amp 3 wire denso with internal red, just want to check i've got the wiring ok. Car has msd, also i have bypassed the firewall plug and ammeter. I have run main power and the sense wire to large stud on relay, sense will be fused, ign is connected to the blue wire from ign switch,also can the lamp wire be connected to the voltmeter. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: wiring a 3 wire denso
[Re: deaks]
#1018591
06/22/11 07:54 PM
06/22/11 07:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would NOT run the sense wire and the output to the same point... it'll sense the output and not the battery... hook up the sense some where after it comes out of the battery.... I dont think you can use the lamp lead as a voltage... that wire shouldnt have power UNLESS the alt quits
[Re: MR_P_BODY]
#1018592
06/22/11 08:03 PM
06/22/11 08:03 PM
deaks
robin hood country
The battery runs to an isolator on the dash, then from there to the relay. Could i put it there and also run a wire from there to feed the volt meter Mick
