Whats a good clutch, have preasure plate, 400HP 360. #1018539
06/22/11 07:01 PM
06/22/11 07:01 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Hey guys, I'm picking up a worked over 360 this weekend( he estimates 400hp), it has a fresh flywheel, and I have a great looking Borg and Beck style preasure plate( surface looks great) I pulled off a 73/74 360 I got and sold that only had 500 miles on it. Question is, what would be a good clutch disk to put in using these parts. I would love to buy a whole new setup like a centerforce but dont know if its in my budget right now, so just looking to use the parts I have and throw in a new disk.
Its a 74 360 with 10:1 KB forged pistons, a racer brown 238 duration and .050 and .485 lift cam with ported and polished heads( 2.02/1.60), a Holley strip dominator ( may swap to RPM Air Gap) and a 750 DP Holley, going into a 72 Duster with close ratio iron 4 speed hooked to 8 3/4 rear with 3.91 sure grip and 325/50-15 DOT street slicks. Am I asking for too much from a Borg and Beck style presureplate with this setup? I was told this motor with a bigger cam went 12.20's in a 68 Corronet with 4.56 gears, but its been tamed down with a smaller cam to make it more streetable.
What do you think?
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 440Satellite] #1018540
06/22/11 10:14 PM
06/22/11 10:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
For just a disc get a McCleod.They last.Now if you were replacing it all Id say Center Force.Rocky
Chrysler Firepower
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 440Satellite] #1018541
06/22/11 11:13 PM
06/22/11 11:13 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
What's you're intended use? If mostly all street a disc with an organic facing will give good service life and smooth engagement. If street and strip a disc with organic on one side and ceramic or metallic on the other would be a good choice. McLeod or Centerforce would be good choices for either. Sachs makes good organic clutches, not sure if they have dual facings.
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 5spdcuda] #1018542
06/22/11 11:21 PM
06/22/11 11:21 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Thanks, Its going to be mainly a fun car to tear up the streets on the weekends and a trip or 2 to the track for fun . You think a OEM style B&B will do the job?I'll look into Mcleod and Centerforce 10.5's.
Butch
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 440Satellite] #1018543
06/23/11 12:15 AM
06/23/11 12:15 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I installed a centerforce street/strip type disc useing factory reman PP/FW & new throwout bearing in my 97 Z28, It worked great, even leaving on the bottle with DRs @ 4K, that would be my pick. Just remember to break it in "properly" no matter what anyone tells you .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 440Satellite] #1018544
06/23/11 12:31 AM
06/23/11 12:31 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
What do you think?
Butch
I just noticed that you mentioned the borg & beck PP has 500 miles on it, this is the cridical time of proper break-in, just remember it was seated to another disc., I would strongly recammend having it lightly resurfaced so it can mate to the new disc, ask the disc manufacturer what they think before installing it, they may say its fine, but they may not. Nothing worse then installing a clutch set-up (especially with an exspensive disc) only to have it start chattering 1000 miles later
This is the "style" disc i used, it'll work great with what you have. This might be the one for your app.
http://www.centerforce.com/product_details.tpl?cart=130880046220029&partnumber=383269
Company home page.
http://www.centerforce.com/?cart=130880046220029
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: joedust451] #1018545
06/23/11 07:12 AM
06/23/11 07:12 AM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
joedust451, Thanks, good to hear feedback from someone who had used aftermarket clutch with stock style PP. Where can I take the PP to get resurfaced, do places like Napa do this or auto part stores?
Butch
Re: Whats a good clutch, have preasure plate, 400HP 360. [Re: 440Satellite] #1018546
06/23/11 11:41 AM
06/23/11 11:41 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Butch
Thanks, Check with your local machine shops. Yeah, you can run stock PPs with stock style disc, the centerforce disc's has other materials in it for better bite, plus there abit thicker too then a stock piece, look at it this way, its like up-grading to a better brake pad with more bite, but you can still run the stock rotors/calipers.
