fender tag help needed
#1017915
06/21/11 08:14 PM
06/21/11 08:14 PM
Posts: 1,060 Ball Ground GA
TrueTripleX
Ball Ground GA
I have a 70 GTX - second line from bottom startss BL1 P6F8 EF8.... third line from bottom starts BL1 A34 B51... On the top line, in the V codes there is a V21 and a V6X, but NO V9* code, which I believe is for vinyl top. My question is - is this a two tone car Beige top and F8 bottom. I do not have the build sheet so I am coming to my experts. And did two tone cars receive the moldings seperating the top from the bottom?
Re: fender tag help needed
[Re: TrueTripleX]
#1017919
06/21/11 08:50 PM
06/21/11 08:50 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Thanks 70GTX. So how would it show on the fender tag on a 70 car if it were to have a tan vinyl top? And doesn't the EF8 indicate the body color? And if not, what is the EF8 code? Help me with my confusion please
As I said; the EF8 is the upper door frame color (inside the door above the door panel) and matches the interior color (F8). A tan vinyl roof would be V1T
If you post a pic of the whole tag, we'd be able to decode it in it's entirety for you.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 6bblgt]
#1017930
06/22/11 10:25 PM
06/22/11 10:25 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
my car: _26 END + N97 R22 V21 V68 Y14 + M21 N41 N42 N85 N95 N96 FJ5 A34 B51 C16 C55 J25 FJ5 P6XA TX9 204 095187 E87 D21 RS23 V0E 131247 Larry, We should compare notes. 440+6 4-speed 4.10 '70 GTX (US spec) = 136 built ---- how many made in & for CA?
