Need help with Running lights 67 Coronet #101722
08/09/08 07:22 AM
08/09/08 07:22 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
My front running lights worked fine. I swapped out the factory bumper for a fiberglass one. Now they do not work. Ok, just ground the lights. Did that.. nothing. Now I have power from the wiring harness to the light (+ and -) and I tested the light + and - to a battery and it worked. So this would mean I do not need to ground the light. But still they do not work.. Again, have power and ground from harness and lights work when wired to a power source. So is it just the connection between the two? the plug? I must be missing something here..?
RS23L7 4-Speed
Re: Need help with Running lights 67 Coronet [Re: Mopar_Mike] #101723
08/09/08 08:53 AM
08/09/08 08:53 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
You are getting power and they work off the car hooked to a battery.
Has to be the ground, try running a ground directly from the battery and see what happens.
Re: Need help with Running lights 67 Coronet [Re: cyphre666] #101724
08/09/08 01:38 PM
08/09/08 01:38 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You need a seperate ground to the socket with a glass bumper.Fiberglass dosent ground.Rocky
Chrysler Firepower
