Trans to housing Bolt Torq..Diff for Aluminum Housing?
#1017042
06/20/11 04:14 PM
06/20/11 04:14 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I'm doing some final torquing of bolts and service manual says 50 ft/lbs for the 4 spd transmission to bellhousing bolts. It doesn't specify between aluminum or steel belhousing and I was wondering if the torq specs are the same for both. Don't want to strip the aluminum threads.
Any input is appreciated. Thanks....Joe
65 Barracuda 70 Challenger
Re: Trans to housing Bolt Torq..Diff for Aluminum Housing?
[Re: jrwoodjoe]
#1017046
06/20/11 06:26 PM
06/20/11 06:26 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Hey John,
1973 Plymouth Chrysler Chassis Manual. Bell housing I'm using is Aluminum.
73 would have had alum. bell housing whether a big block or a small block so I think your are good to go with that spec. Not sure about /6 or pickups though.
[Re: JohnRR]
#1017047
06/20/11 06:29 PM
06/20/11 06:29 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks guys, Just trying to be safe and not sorry. Joe
[Re: jrwoodjoe]
#1017048
06/20/11 07:09 PM
06/20/11 07:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It would only matter if the bolt was threading into aluminum, it's not. The bellhousing to block bolts thread into the cast iron block.
[Re: Supercuda]
#1017049
06/20/11 07:15 PM
06/20/11 07:15 PM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
same basic question is asked of the torque for the six pack aluminum and cast iron intake manifolds and it's the same because the bolts for both manifolds are torqued into the cast iron threads of the engine block; no threads in the manifold (or housing).
[Re: Supercuda]
#1017050
06/20/11 07:31 PM
06/20/11 07:31 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
It does matter, not bolting to block. that has already been done and torqued. Bolting Trans to Aluminum bell housing. But I agree with what you posted.
