340 / 360 Fuel Line Pic Request #1016916
06/20/11 01:36 PM
06/20/11 01:36 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Does anyone have pics of the fuel line from the pump to the carb (focusing on the pump side) on a small block.
I just installed a fuel pump on my 360 and want to bend up some lines for it and wanted to get a visual of how they went.
Thanks,
Jason
Re: 340 / 360 Fuel Line Pic Request [Re: CUDAJAS] #1016917
06/20/11 01:58 PM
06/20/11 01:58 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Factory for modified?
Factory goes in the small space between the alternator and the block. The line takes a quick right angle out of the fuel pump that is hard to bend with a hand bender. Or you run a 90 degree adapter that the fuel makes a super sharp tubulent turn.
This is the idea Troy came up for my small block motor. Then I put fire-sleeve heat protection sleeve over all the lines..
