Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016670
06/20/11 05:34 PM
06/20/11 05:34 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
OK!!!!!
THIS IS WHY I ASKED.......NO REAL DEFINATE ANSWERS ON A 383VS440
I HAVE READ THAT THE 383 HAS THINNER CYLINDER WALLS AND WILL FAIL SOONER IF BORED.
AS FAR AS THE 440 I'VE READ THE 67-68 BLOCKS ARE BETTER,SO I GUESS ALL BIG BLOCKS ARE NOT THE SAME!
SO IS THERE ANYONE WHO HAS BUILT SEVERAL BIG BLOCKS AND PERSONALLY KNOWS THE DIFF. SPECS OF BIG BLOCKS?
THANKS FOR THE INPUT GUYS.......STILL UP IN THE AIR WHAT IS THE BEST BUILD I GUESS?
I've read articles that stated the mid 70's blocks are better than the 60's blocks...I have a 72 only 030 over and a 76 stroked to 498...happy with both
Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016671
06/20/11 05:37 PM
06/20/11 05:37 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
THERES A VIDEO ON YOUTUBE CALLED CHALLENGER FROM A ROLL......HE HAS A COUPLE VIDS OF HIS BLUE CHALLENGER.......I WANT MINE TO DO THAT!!!!
Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016672
06/20/11 06:13 PM
06/20/11 06:13 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
OK!!!!!
Here you go; everything you ever wanted to know about 440 blocks;
http://www.440source.com/blockinfo.htm
Basically, any 440 block in good condition can be used and the differences between them all are VERY minor.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: BIG BLOCK VS SMALL [Re: DPelletier] #1016673
06/20/11 06:33 PM
06/20/11 06:33 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
WELL THAT ANSWERS THE QUESTION ON WHAT YEAR OF 440 ARE BEST BUT WHAT ABOUT THE 383 VS 440 SPECS?
Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016674
06/20/11 07:39 PM
06/20/11 07:39 PM
DPelletier Offline
DPelletier  Offline
Well, they are the same basic design, using the same heads; the 383 is smaller and the 440 is bigger.
OK, here;
http://www.allpar.com/mopar/383.html
..there's the specs for you. Basically, expect the 440 to produce about the same hp difference vs. the 383 as thier size difference would suggest; about 15%
Re: BIG BLOCK VS SMALL [Re: DPelletier] #1016675
06/20/11 07:47 PM
06/20/11 07:47 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
THANKS,SO GUESS IF I PURCHASE A CAR WITH A 383 THEN I'M BUILDING THAT SINCE THE SPECS ARE SO CLOSE AND THE EXTRA PURCHASE COST WOULD OUT WEIGH THE HP/TQ OF A 440
Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016676
06/20/11 07:57 PM
06/20/11 07:57 PM
DPelletier Offline
DPelletier  Offline
If you are buying a car that has a 383 and it's an original 383 car and you want 500hp, then I would suggest stroking the 383 or using a 400 stroker (451 cu in) to get your 500hp. You can get it with 383 cubes, but it will be a much more radical build.
OTOH, if you don't care about originality, then you may be $$$$'s ahead to get a 440 anyway....it's not like 440 cores are all that expensive and you can use the heads and many misc. parts off the 383 anyway.
Re: BIG BLOCK VS SMALL [Re: DPelletier] #1016677
06/20/11 08:00 PM
06/20/11 08:00 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I KNOW OF A 440/727 HP FOR 600 BUCKS ACTUALLY
Re: BIG BLOCK VS SMALL [Re: DPelletier] #1016678
06/20/11 08:03 PM
06/20/11 08:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If you do care about origanality then a 400 won't do in a 383 car, as it aint origanal. My vote would be to find a reasonable car and hop up what ya got. They can all be made to smoke tires. Build for torque. Just don't expect good gas mileage. Just one opinion. Have fun what ever you decide.
I also agree you need to turn your cap lock button off as all capital letters is concidered yelling on the web. It's just good manners.
Re: BIG BLOCK VS SMALL [Re: CUDA8U] #1016679
06/21/11 12:15 AM
06/21/11 12:15 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
OK!!!!!
Simple answers: Fewer dollars invested, simple mods, go 440 cubes, especially with a 3800-4200lb B-body car!
Lighter car (by 700-1000lbs less or A-body), some dollars to invest in BETTER intake and heads, love the sound of a screaming big block, go 383 cubes, especially with a stick behind it!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: BIG BLOCK VS SMALL [Re: HYPER8oSoNic] #1016680
06/21/11 02:43 AM
06/21/11 02:43 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
KILL THE CAPS WOULD YOU!
easiest to build a 440 to get 500hp
Astroker small block will get you there with a 1400 set of RHS heads like what Brian at IMM does. A bunch have been built with good result and Hydraulic cams.
