Re: PAGING Engine Builders B/RB Question
[Re: MoparforLife]
#101659
08/08/08 11:25 PM
08/08/08 11:25 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Don, IIRC the pad is 1" thick on the BB heads as stock, pretty easy to tell if they have been cut.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: Jopar]
#101661
08/09/08 12:22 AM
08/09/08 12:22 AM
Posts: 8,064 Arlington, Texas
earlybee
Arlington, Texas
I am building a 75 440 engine w stock pistons and a CompCams XE268H.
I found a good deal on a set of 452 heads all set-up and ready to go. One problem, I did a dry fit onto the block and found that the heads are milled about .125. What is the advantages to doing this? Also, the intake will need to be machined. What should I do about push rods and valve to pistion clearance?
Thanks for the help..
Pass on the Good Deal.
[Re: Jopar]
#101662
08/09/08 12:29 AM
08/09/08 12:29 AM
Posts: 1,075 United States
STLDuster
United States
I put together my '73 440 with the stock pistons that ended up right around .098 to .10 down in the bore. I am actually running the same cam from Comp Cams, the XE-268H. But I am using a set of 516 Closed chambers with the bigger valves (hardened seats) from my 346 heads. I want to say I had about an 1/8" of valve to piston clearance at the nearest. I would have to say that you would be opening a can of worms with those head milled that much. I would agree, - PASS
"No great genius has ever existed without some touch of madness." - Aristotle
