Stack Injection Using a Lot of Alcohol #1016550
06/19/11 11:55 PM
06/19/11 11:55 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
We finally got my 512 RB with Hilborn mechanical injection fired up today But I have some questions/concerns First off went through about 8 gallons of alcohol with about 10 min idling time at the most Is that normal We could hardly get any heat in the motor at all, is that because we are running way too rich and using all that alcohol and if so how do I lean out the idle When I dropped the oil it was milky, is that normal as well Also had a fair bit of moisture coming out of the exhaust, is that normal I did have the electric water pump running for a bit but no electric fans running and I am running no thermostat, is that right
Also the only weay it would fire is spraying alcohol in the stacks even after it ran for a few minutes, is that normal as well
Do I need to plumb in some sort of primer system and is it easier/better to try and start on gas rather than alcohol
I had Dodgem and another buddy over to set-up the injection and it seems real snappy when I blip it but my buddy who set it up runs his injection stuff on gas so is there a big difference in the way you set them up and idle quality
Sorry for all the questions but want to get this right so I don't wash down a fresh motor
Derrick
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016551
06/20/11 12:40 AM
06/20/11 12:40 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Probably more like 20 minutes running if not a tad more.
was way leaner after you changed the jet!
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016552
06/20/11 12:44 AM
06/20/11 12:44 AM
gregsdart Offline
gregsdart  Offline
Way too fat, is my guess. Look at the linkage between the throttle arm and the barrel valve. You want to lean out the motor, so loosen the jam nuts on both ends, and lengthen the link by three flats or so, to start. Keep track of the moves you make.
Start up the motor, and keep lengthening the adjustment till the rpms rise at least four to five hundred rpm over your normal idle rpm. This will be most likely lean enough to build heat in the motor. Once you have it to the temp you want to run at, fatten up the idle by shortening that link till the motor has instant throttle response.
To warm the motor once you have the barrel valve set, push the fuel shutoff patially closed, keeping an eye on exhaust temp, or enough to raise the idle as before. You will notice the motor won't like to be real lean until you get some heat in it, so be patient, leaning out a little at a time with the shutoff as it warms up. Also, you probably have fuel draining out of the injector lines when you shut off the motor. When you shut the motor down, starve it to death with the fuel shutoff, then hit the starter again after about thirty seconds, and it will run a bit and burn off the fuel that drained into the cylinders.
To restart, put the throttle to the floor, crank till it pops, quickly back off the throttle till it starts. May take five seconds or so. Keep the motor lean as much as you can to keep the fuel clear, and heat up the motor real good (210+) to clear the oil.
Re: Stack Injection Using a Lot of Alcohol [Re: gregsdart] #1016553
06/20/11 12:55 AM
06/20/11 12:55 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
your dead fat for sure, like was posted lean out the barrel valve till you loose your throttle response then come back a flat or to till it returns. there is so much to a simple injection people often overlook the important things.
Did you leakdown the barrel valve before you started it? 20-25% is a good start with around .002-.005 of butterfly to runner clearence
What are your pump flow numbers?
What size nozzels are you using?
what size main jet and whos jet is it?
how much total horsepower do you think you will be making?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Stack Injection Using a Lot of Alcohol [Re: bigtimeauto] #1016554
06/20/11 01:27 AM
06/20/11 01:27 AM
Ontario, Canada
Ontario, Canada
Yes my buddy did a leakdown on the barrel valve. Went by Kinsler book for my cubic inch and set it at 18%. Butterly clearance is at a tight .004
Enderle pump(new), not sure on flow numbers but was what Alky Digger recomended. I belive it's part #80A??
Not sure on nozzles but same thing, what was recommended by Mike @ Alky Digger.
Mian jet was .070 and changed to .080 (Hilborn)and did get better but still seems real fat.
H.P I am guessing approx 750-775 at crank.
Did not adjust/close off shutoff valve at all during fireup and idling, ran it full wide open all the time. Will that not make the idle come way up Idles at about 1300 the way it is now but seems real snappy on the throttle
Derrick
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016555
06/20/11 01:40 AM
06/20/11 01:40 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Jetting is fat on injection on purpose. Reason being that you have no pump shot like a carb has. The injection must run rich at idle to overcome this. That being said, it sounds fat to me and as stated you lengthen your rod to lean it out. Rule of thumb "Its like a woman. Long and lean or short and fat" Quote James Monroe. I thought it was funny but I will never forget which way is which now. Lean it out till it starts to "dead bog" or hesitate when you crack the throttle then shorten the rod till the hesitation goes away. After you get it there and running correctly, start idling around the pits with the barrel valve halfway closed. Pull your fuel shutoff slowly till the engine starts to rev up and leave it there. If my car aint going out on the track, its halfway closed. It helps to build and maintain heat in the engine. I am actually using less fuel using this method than I was with the carb. If you get to hot lapping with no downtime between rounds just leave the barrel valve open when coming up the return road. It will use more alky but will keep the engine cooler. Just some general guidelines that I have learned in the first 5 weeks of running my Terminator. I must say it has been really mean though. Now if I can just remember to open the barrel valve before trying to start the car
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Stack Injection Using a Lot of Alcohol [Re: Irun5snd8th] #1016556
06/20/11 09:57 AM
06/20/11 09:57 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
LOL Been there done that.
Re: Stack Injection Using a Lot of Alcohol [Re: mac56] #1016557
06/20/11 11:36 AM
06/20/11 11:36 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That happened a time or two yesterday!
Re: Stack Injection Using a Lot of Alcohol [Re: Dodgem] #1016558
06/20/11 12:11 PM
06/20/11 12:11 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I feel better knowing that I am not the only one that does it
Re: Stack Injection Using a Lot of Alcohol [Re: Irun5snd8th] #1016559
06/20/11 12:48 PM
06/20/11 12:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
All good advise.
Since you are circulating the water, it's going to take a bit longer to get up to temp. On the first warmup, you can leave the WP off for a while too. Just make sure to turn it on later!!!
Keep an eye on the oil while getting used to running this deal. You will go through a lot of plugs and oil at first!
You don't mention the support systems. Having a fuel tank above the pump will help with the prime.
Having an evacuation system will help with milking the oil, but just idling probably won't pull enough fumes.
Keep track of fuel usage too, even if you have an O2. My buddy with a small block and a carb runs right around 4.9-5.1 down the track. Alky is more forgiving than gas, but you are starting from the right side (rich).
Re: Stack Injection Using a Lot of Alcohol [Re: Irun5snd8th] #1016560
06/20/11 01:10 PM
06/20/11 01:10 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The 1st time for the day I use squirt a little gas in all 8 throttle bores on the terminators,and it fires right up if I remember to open the shut off valve. For the rest of the day I just open the shut off valve and be ready to pump the gas pedal(acts like one does when its running out of gas) a time or two till the engines catches up.Ron's sell a primer system to cure this problem,but there is not enough room for another tank to hold gas,don't want the added weight and don't have the spare$$$. So I have gotten used to it.
PS Mine never milks the oil,the oil out of it looks just as clean as the oil out of my Lincoln. But I use my lean out valve to warm it up,and when its in the high 90's like the present I never have to lean it out. I think it might would stay around 175 degrees if I run let it run all day.
Just called and checked the price of VP M5 $279.00 VP M1 $179.00 per drum.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Stack Injection Using a Lot of Alcohol [Re: MRMOPAR622] #1016561
06/20/11 04:58 PM
06/20/11 04:58 PM
No. cal., sacramento usa
speedy383 Offline
speedy383  Offline
Sounds like you are very rich, 20 % is close but idling for long time with barrel valve fully open will milk the oil.To put heat in it pull the cable towards shut till it leans out,no need to give all the fuel till the burnout box. That M5 is expensive but a friend with a best of 9.57 did a back to back test and went 9.42 .had to change pill (richer) to get max benefit.
Re: Stack Injection Using a Lot of Alcohol [Re: speedy383] #1016562
07/05/11 01:29 AM
07/05/11 01:29 AM
Ontario, Canada
Ontario, Canada
Had the car running again tonight. Used gas in a squirt bottle and fired right up Tried to run it with the shut-off valve half cloed and it does seemm to be much leaner at adle but idles at around 2500 rpm then The way it is set now only will idle at a half decent rpm with valve wide open
Even with valve about half closed I still went through about 3.5 gallons in 15 min or so of idling I haven't touched the linkage because my buddy told me not to $@#! with it
But no way I am going to be able to drive to the lanes, make a pass and drive back using this much alcohol
Derrick
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016563
07/05/11 03:17 AM
07/05/11 03:17 AM
speedy383 Offline
speedy383  Offline
I use around 3 gallons on first run,warm up ,tech,etc.The rest of the day 1/1/2 to 1/3/4, You have more hp.but 1 am over 3000 lb at 9.65et.I can run mine at home for 15/20 minutes on one gallon or less cold.The barrel valve either has a problem or your probably have 30 or more % leakdown,The main pill wont really affect it that much at idle. Keep lentghning the rod till you get a stumble when you snap the throttle then go back (richen one flat) then see what your leak down is,The % is figured on a graduation of the air in gauge ,if you dont maintain 100 lb pressure on that one you have to calculate % on a graduated basis,.Sorry so long ,this stuff is simple but difficult to explain.
Re: Stack Injection Using a Lot of Alcohol [Re: speedy383] #1016564
07/05/11 03:23 AM
07/05/11 03:23 AM
speedy383 Offline
speedy383  Offline
Just talked to a Hillborn user 10.0 at 3300LB big block, His main pill(bypass)is 89.You really cant copy other tune ups as similar numbers will flow different but its in the ballpark.His barrel valve is set at 19%.
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016565
07/05/11 08:33 AM
07/05/11 08:33 AM
gregsdart Offline
gregsdart  Offline
If the idle was set with the motor cooler than the temp you run at, it is probably still too fat. You will use more alky if you are trying to run the car at a lower temp than say 180 to 190 degrees. I see about 500 degrees exhaust temp at idle, full warm ready to run at 185 degrees. My system varies by a flat or two on the barrel valve adjustment from hot summer to cool fall days. You can set the idle , just remember exactly what you did so you don't lose the base setting. From where you are at, I would warm the motor to operating temp, then lean it out a couple of flats and see if it is crisp when you snap the throttle open quickly. That is what you want. Move leaner till it doesn't have that crisp response at operating temp, then go back a little at a time till it does. You want it just barely rich enough to be vary responsive, no hesitation. You will get there, just keep working at it and you will get comfortable. It would be a good idea to print all the posts on this thread and keep them with you till working on the system becomes second nature.
Re: Stack Injection Using a Lot of Alcohol [Re: speedy383] #1016566
07/05/11 08:45 AM
07/05/11 08:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
People would come by our pits and ask about my injection because we always quialified #1 or 2 or 3. I always talked to them, but never told the truth about my setup. It's racing, it's competitive. Why would I tell you my tuneup for free?
Like what was said, everyones setup is different and if you listen to too many people your not gonna win or run worth a hoot.
Get out there and run the car and make changes and don't worry about the other guy. You will never learn until you make changes and see how the car runs.
If it's milking the oil, it's not right and they are not made to idle for 15 minutes.
The best way to prime the motor is with gasoline in a presurized sprayer that atomizes the gas. Only need to do it when the motor is cold.
Re: Stack Injection Using a Lot of Alcohol [Re: Hyper Henry] #1016567
07/05/11 09:47 AM
07/05/11 09:47 AM
NC
440Jim Offline
440Jim  Offline
NC
You are going to have to lean out the idle with the barrel valve linkage, or have somebody do it.
Everything you posted shows it is way too rich at idle. Including when you lean with the shut off valve the idle goes much higher. It is normal when leaning with the shut off valve for the idle to go up, and that actually helps driving in the pits (little/no throttle needed). And after adjusting the barrel valve, readjust the idle throttle blade position. Keep notes.
Don't confuse rich at idle and rich going down the track at WOT. You can adjust the idle with the barrel valve setting, and the WOT with the main bypass pill/jet.
Re: Stack Injection Using a Lot of Alcohol [Re: 440Jim] #1016568
07/05/11 11:05 AM
07/05/11 11:05 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
as stated, every combo is different.
Your idle mixture is obviously WAY off. My old combo liked 28%. You can make changes with leakdown guage or lean it till it stumbles when you whack the throttle the enrichen by one flat on the linkage.
You MUST be able to use your leanout to build heat, or your just pumping alky to the crankcase and will not get a good ring seal.
Re: Stack Injection Using a Lot of Alcohol [Re: MegaDart] #1016569
07/05/11 01:23 PM
07/05/11 01:23 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
www.hre.com and Spud Miller at Fuel Injection Enterproses have math formulas that will get you a starting baseline to work from. If your pump is an 80A, it's around a 6.8 gallon a minute pump. You are fat! With your cubic inches and the intake that you have, your fat. You could go to a 100 pill in the main, and it would be close I bet. The other thing that so far nobody mentioned is that when you change your main pill, if your barrel valve is spot on, you will have to adjust it a flat or two. Until you get close with your tune-up, you will want to make changes of 12 - 16 number on your main pill. You're looking to make heat in the motor and show heat on the plugs. Once you get close, then make changes of 4 numbers at a time: 100, 96, 92 or 100, 104, 108. Once your happy with how the car is running, then you might want to think about adding a high speed lean-out to further dial in the system.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
