Hood Release Handle #1016411
06/19/11 06:44 PM
06/19/11 06:44 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Any one have a shot of a hood release handle installed for an E body? how close is it to the ebrake handle.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Hood Release Handle [Re: 19cuda73] #1016412
06/23/11 09:00 AM
06/23/11 09:00 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I've heard this is a rare option on ebodies but if anyone has a picture of where it goes on the dash that would be great. I have seen A bodies that had a bracket holding it on.
1972 Corvette
Re: Hood Release Handle [Re: 19cuda73] #1016413
06/23/11 09:44 AM
06/23/11 09:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
there should be holes or dimples where the screws would go ? A body I had the handle screwed to the dash frame .
Re: Hood Release Handle [Re: 19cuda73] #1016414
06/23/11 11:22 AM
06/23/11 11:22 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
There's only one place it can go, and it's very logical. Just to the left of the e-brake handle, next to the kick panel. If you notice in your pic, the top of the plastic bracket on your release is angled. I added one to my 73 Challenger. Look under your dash. You will see exactly where it goes. The underside of the dash is shaped with the same angle as the release mount, and you will see two screw holes, which will align with the two holes in the release mount...
Re: Hood Release Handle [Re: 318 Stroker] #1016415
06/23/11 02:07 PM
06/23/11 02:07 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Guys I'll double check it tonight and screw it on>>
1972 Corvette
