Victor 340 on Magnum Eddy Heads #1016385
06/19/11 05:10 PM
06/19/11 05:10 PM
Maracaibo,Venezuela
GTMaracucho Offline OP
super street
super street
Maracaibo,Venezuela
I`m Planing built a Magnum 360 and want to put a Victor 340 on there, but the problem is the heads that i`m planing to use are aluminum ones.
What is the best way, put the Victor 340 or buy a Magnum type M1 ??ç
Regards....Jose
Re: Victor 340 on Magnum Eddy Heads [Re: GTMaracucho] #1016386
06/19/11 06:53 PM
06/19/11 06:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the heads can be redrilled to the LA bolt pattern...or you use the Mopar M1 as it is the only single plane with Magnum bolt pattern
Tony
70 AARCuda Vitamin C
Re: Victor 340 on Magnum Eddy Heads [Re: 70AARcuda] #1016387
06/21/11 12:11 PM
06/21/11 12:11 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Unless you have lots of stall and low gears, the Victor will be a pig on the street
Re: Victor 340 on Magnum Eddy Heads [Re: 70AARcuda] #1016388
06/25/11 11:16 AM
06/25/11 11:16 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I seem to recall that the Eddie heads have helicoils in the holes, redrilling the heads might not be a great idea.
Better off to get a comparable magnum intake.
Re: Victor 340 on Magnum Eddy Heads [Re: GTMaracucho] #1016389
06/25/11 04:01 PM
06/25/11 04:01 PM
SoCal
Brian Hafliger Offline
SoCal
Regards....Jose
If you want performance, use the eddy rpm air gap. If you want looks, use Indy's intake.
Brian
Brian Hafliger
Re: Victor 340 on Magnum Eddy Heads [Re: babarracuda] #1016390
06/25/11 06:18 PM
06/25/11 06:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I run the Vic340 on my 340 with Edlebrock LA heads, it's runs great down low. 3:55 gears and a small stall converter. I have always ran a single plain Weiand for like 15 years. Then thought I'd try a RPM manifold because it's dual plane, hated it. Motor ran out of power early for me. Tried a M1 , didn't like it. Then tried a Vic 340 and it runs like my old Weieand that I sold,(wish I would have kept)
Anyway a single plain manifold can be made to scream on the street, mine does with the 474 MP cam and 600 carb. I just got done driving it all around town in traffic today with the AC on. It ldles great with just the right amount of rumble, it snaps necks looking at it everywhere I go.
