Base/Clear paint,, how many coats of clear should I do #1016318
06/19/11 04:12 PM
06/19/11 04:12 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
I've been in the garage all morning getting started on my paint job.
Using base/clear (sherwin williams). It says to use 2 medium wet coats. Is that sufficient ? or should I do another.
It will need a little sanding/buffing. For some reason as soon as I started with the clear my gun started dripping, so I have a few drip that will need sanded out anyway.
So, do a third ? or leave it at 2 coats ?
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016319
06/19/11 04:15 PM
06/19/11 04:15 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello, Really depends on how much color sanding you'll need to do. I usually put on 3 coats of clear. Then you can start color sanding in a couple days. Don't sand between clear coats tho. Hope this helps. Jeff
Re: Base/Clear paint,, how many coats of clear should I do [Re: 1969RR] #1016320
06/19/11 04:18 PM
06/19/11 04:18 PM
Lyons, CO
Lyons, CO
Yep, I just went at and gave it a close look over. I have quite a few specks of dust, and a few drips so I think it will need a pretty good color sanding.
So I think I'll give her a third.
I'll post pics soon.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016321
06/19/11 04:22 PM
06/19/11 04:22 PM
Kirkland, Washington
Pacnorthcuda Offline
3 coats is your best bet. Also regarding drips/runs---DON'T try to sand them out--you're likely to create wallows and go through the clear.
Instead take NEW razor blade and scrap the high points down while holding the blade 90 degrees (vertical) to the paint surface. Lightly back and forth until the topography of the surface is correct. Then buff.
Wait a minute---I am thinking here.....Are your drips/runs in the basecoat?????? You should correct that before clearing the car.
Otherwise you will cut through the clear you lay over the defect.
---Edit---I reread your post--you're good. Just razor scrape as stated. And sand areas of orange peel, light dust.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016322
06/19/11 04:29 PM
06/19/11 04:29 PM
Jacksonville Florida
elitecustombody Offline
i'm assuming you wil allow the clear to harden before sanding,i'd advise applying 2-3 more coats,because it will have to be sanded
and buffed
Re: Base/Clear paint,, how many coats of clear should I do [Re: elitecustombody] #1016323
06/19/11 05:16 PM
06/19/11 05:16 PM
Lyons, CO
Lyons, CO
Yes, I'm going to wait a couple days before doing any sanding.
Good tip about using the razor blade to take care of the drips.
Right now I am only painting the hood and the trunk lid, (they are off the car). Using them as a learning experience before I move on to the rest of the car. I'm basically panel painting it, hood, trunk, doors, fenders all separate from the roof/quarter panel part of the car. Shouldn't have any paint match problems between panels, I got enough paint to do it all, and a little extra. And its a solid color, not metallic.
p.s. I think I'm going to stop at 3 coats. They were good wet coats and I only have some minor dust in it, and a few drips to shave off. And a couple of very very small bugs that had to show up of course.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016324
06/19/11 05:40 PM
06/19/11 05:40 PM
Lyons, CO
Lyons, CO
Hood after 3 coats of clear.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016325
06/19/11 05:40 PM
06/19/11 05:40 PM
Lyons, CO
Lyons, CO
trunk lid after 3 coats.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016326
06/19/11 06:38 PM
06/19/11 06:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
On the razor blade technique, if your hands are good & steady go for it, but be aware of the corners of the blade, they can do damage pretty quickly.... I'm not the steady so I wrap the corners with a couple layers of masking tape leaving 90% of the edge available for scraping but the corners covered to protect the paint....
Also when laying down the clear be sure to allow time between coats for the solvents to flash or you'll wind up with tiny bubbles trapped in the clear.....
Re: Base/Clear paint,, how many coats of clear should I do [Re: 1_WILD_RT] #1016327
06/19/11 08:33 PM
06/19/11 08:33 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Concerning the razor blade technique, I lay a pice of 400 grit or thereabouts sandpaper on a flat surface and run the corners of the blade back and forth over the paper to round them off . As mentioned, you can gouge the paint with a corner pretty easily if you're not steady.
Re: Base/Clear paint,, how many coats of clear should I do [Re: forphorty] #1016328
06/19/11 10:11 PM
06/19/11 10:11 PM
Just invest $10 in Steck nib file
Re: Base/Clear paint,, how many coats of clear should I do [Re: elitecustombody] #1016329
06/19/11 11:38 PM
06/19/11 11:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I never liked that little thing...
Re: Base/Clear paint,, how many coats of clear should I do [Re: 1_WILD_RT] #1016330
06/20/11 12:48 AM
06/20/11 12:48 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Me neither
Re: Base/Clear paint,, how many coats of clear should I do [Re: forphorty] #1016331
06/20/11 01:23 AM
06/20/11 01:23 AM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
Much of what is suggested here is great advice. But a lot of people think painting a car isn't any more technical than turning wrenches. Yeah...OK!
Mind if I add a few things?....having 23 years experience as a professional painter, factory trained by BASF(Glasurit) and PPG, I can tell you that it's not hard to go too far when finesse sanding a surface. And there are factors involved like dry/cure times and windows i.e. there is a 'window' of opportunity to sand and buff the clear. Too soon and you'll leave scratches that are almost impossible to remove; too long and it gets hard as a rock costing time and sandpaper. And careful with that razor! Make sure the clear is completely dry/cured before attempting. You can't go at it the next day unless you've actually baked the paint. If you can still put a fingernail mark in the clear, it aint ready. If I were you, I would let the clear dry for 3 days or so before working on it. Just my humble
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Base/Clear paint,, how many coats of clear should I do [Re: BFASTER] #1016332
06/20/11 01:47 AM
06/20/11 01:47 AM
Lyons, CO
Lyons, CO
Bfaster, thats for the tips.
I'm planning on at least 2-3 days before I attempt to sand or scrap the drips.
I know that being a great painter takes education and lots of practice, etc.
Believe me, after doing my own bodywork, and now attempting my own complete paint job, I have nothing but respect for people that do bodywork and painting for a living
I'm a total rookie and not afraid to admit it, but on my budget its do it myself or dont do it.
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016333
06/20/11 09:11 AM
06/20/11 09:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
your rookie job looks to be coming out as good as my rookie job! only I just did a few panels, not a full on re-paint. keep up the good work!
in my other post titled 'ooh aaah' I posted a pic of my mirror. I painted and cleared it last wednesday, I razor bladed a run/drip, wet sanded it smooth, and hit it with a buffer last night. turned out pretty good, so I'm ready to try the rest of the truck, and will probably buff the whole truck, since the factory clear, although still good, does have some swirl marks in it.
**Photobucket sucks**
Re: Base/Clear paint,, how many coats of clear should I do [Re: 1_WILD_RT] #1016334
06/21/11 01:36 AM
06/21/11 01:36 AM
it's much more predictable than razor blade
Re: Base/Clear paint,, how many coats of clear should I do [Re: MileHighDart] #1016335
06/21/11 02:07 AM
06/21/11 02:07 AM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
my first body/paint project i was able to befriend a seasoned body man that was willing to give me good deal on a complete paint job provided i helped him,i was glad to learn.I do remember him spraying 4 coats of dupont primer very heavy,cured for 24hrs then he thinned some cheap grey primer and sprayed a light coat that dried in an hour,out came the boards.....we sanded,and sanded and sanded.The grey primer remained in the low spots,we wiped down the truck and reshot the dupont with 2 more coats and reboarded again after grey primer,this continued until there were no more low spots.
We then wet sanded in many different grits all the way up to 1200 i believe.
We were ready for paint!!!!After cleaning up the truck with solvent and tack clothes we left the paint booth for 1hr to let any dust settle and repeated tack clothing.He then sprayed 4 coats of seguins paint,48 hrs later we came back to wet sand for hrs again to get ready for clear.I remember him saying if you want a deep bright and shiny wet look to ad extra hardner........I must say i have yet to see a deeper,brighter and shinier paint job......4 coats of clear!!!!
this paint job got me multiple compliments and still was shiny even after 10yrs outside in a brutal Canadian winters
Re: Base/Clear paint,, how many coats of clear should I do [Re: CUDA8U] #1016336
06/21/11 08:40 AM
06/21/11 08:40 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sanding drips with a razor can be tricky.the tech. i use is to slightly bend the razor blade ,then hold it so it forms a "U". lean it back slightly then pulling down in one direction only, you can scrape your drip down to a sandable level.
