Header Coatings/Paint
#1016265
06/19/11 02:26 PM
06/19/11 02:26 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I have been doing some research on coatings and paint. With the coatings, are they "scratch proof" or do they scratch the same as a painted header? Do coatings wear off over time, break down, rust, etc?
Trying to decide which way to go. I like the idea of paint, if I can make it look good, and hold up, because the headers might need to be tweaked in the future. Having them coated is going to make it hard to swallow if I have to move a primary tube. These are TTI 2" headers going on a B-engine.
I've searched the forums here, and the net, with mixed results. Some get paint to hold up really well, some not, some have had coatings chip, fade, etc. I have a local powder coating guy that I am going to talk to and see what he has to say.
What do you guys think?
383, Hemi 4-Speed, AlterKtion, D60
Re: Header Coatings/Paint
[Re: Crazy68Dart]
#1016266
06/19/11 02:36 PM
06/19/11 02:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use QC Coatings for my headers... if you have them coated make sure they fit first... you would have to grind off the coating if you need to do any welding
[Re: Crazy68Dart]
#1016267
06/19/11 02:38 PM
06/19/11 02:38 PM
Posts: 2,177 ill
dennismopar73
ill
mine are ceramic coated, love the look , had them all fitted and placed in the car for bot low and tall decks then sand blasted then coated . have had other guys painted with high temp paint and put in oven to cure, and they have held up very well over 6 years with not much fading , i dont do spray can as this just doesnt work usually blows off quickly. as for scratching any can scratch , the good about ceramic i can rub it a little with mothers and its gone . prep is the secret here,as well as oven temp!! dont do infered lite at all
[Re: topside]
#1016269
06/19/11 02:59 PM
06/19/11 02:59 PM
Crazy68Dart
Canton, Ohio
Been through this a few times over the last 30 years or so...had porcelain on one car, and when they baked the headers, they straightened out a little bit and the fit changed; later on the porcelain developed little cracks like lacquer-checking. The Jet-Hot kind of stuff seems to last forever, but you need to have the header fit finalized beforehand. I've used Eastwood's Stainless Steel exhaust paint on a couple of cars' headers - sprayed on, reduced a bit with enamel reducer - and it worked fine in a dry climate. Gotta bead-blast first, but whatever mods you need to make can be touched up by gun or foam brush. I always cut & trim back the header flanges to eliminate warpage & increase plug access.
Is it the brush-on stuff you used or the product that is to be applied with a airbrush?
I am leaning towards giving the paint a shot. Get them blasted first, prep good, etc. I plan on throwing together a test stand to run the engine before it goes in the car, that will be a good chance to bake the coating good, and see how it holds up. If it turns to crap, I guess I could send them out for coating at that point.
[Re: Crazy68Dart]
#1016270
06/19/11 04:12 PM
06/19/11 04:12 PM
Posts: 7,506 Az
Crizila
Az
Having mine "JetHot" coated ( in and out )as I type. I've heard good stuff about it, but - - I pick them up next week.
Fastest 300
[Re: topside]
#1016272
06/19/11 05:18 PM
06/19/11 05:18 PM
Posts: 93 CA
mojavered
CA
Is that the Eastwood stuff? Can you post a part number or link?
71 Challenger RT 440 / 727 / 8.75
[Re: convertriple]
#1016275
06/20/11 08:59 PM
06/20/11 08:59 PM
Crazy68Dart
Canton, Ohio
So, what I have found so far...
- Eastwood product seems to be the best bet as I found multiple instances where guys said it holds up decent. - Blast the surface - Wipe down with surface prep or similar - Apply paint - Start engine, first sign of smell or smoke, shut it down. Do this heat cycling over and over until there is no more smell/smoke. This helps you not burn the paint off and "bakes" it on.
An oven is out of the question, these TTI headers are huge. Unless I can find a big oven that I can rent or something, probably going to use engine heat to cure.
I'm still skeptical, we'll see. The Eastwood stuff says 1000 degrees, EGTs are higher than that.
[Re: Crazy68Dart]
#1016276
06/20/11 09:17 PM
06/20/11 09:17 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
this is for crazy68dart. eastwoods ceramic coating is good for 1,300 deg. i modified an old electric oven, made it 4'6" tall inside, just cut the top off the oven & used old sheet metal & wrapped with insulation. it's an easy job. it's not pretty lookin lol but it works. my old headers had jet-hot on them, they still rusted. had tti's, they rusted after 1 year, so i don't think any of them last. for 50 bucks u can do ur own. if they go south in a year or so, u can redo them. still cheaper than spending big bucks to recoat plus shipping. i sprayed mine, baked for 1 hr. they came out great. stay safe, seeya, Rick,
[Re: rickraw]
#1016278
06/20/11 10:59 PM
06/20/11 10:59 PM
Crazy68Dart
Canton, Ohio
Did you use this...?
http://www.eastwood.com/exhaust-detailing-kit-silver-high-temp.html
or this...?
http://www.eastwood.com/tlc-colorgard-stainless-kit-w-polish-4oz.html
[Re: cudadoug]
#1016279
06/20/11 11:00 PM
06/20/11 11:00 PM
Crazy68Dart
Canton, Ohio
Been doing this for 30 years...but you have to like black headers!!
A hand held propane torch (or heat gun) and BBQ paint.
Sand blast header Heat section of pipe Apply BBQ paint in moderatation Reapeat until all of the header is painted It never burns, flakes, nothing, just sticks. If you spill oil, it WILL burn off and completley disappear with no spot in the paint.
My local Hardware chain now has BBQ paint in Silver, so I'll try that next time and see what it looks like.
Thanks for the tips. Brush on the paint or spray?
