replacing e body dash harness? #1016227
06/19/11 12:38 PM
06/19/11 12:38 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, is it possible to replace the dash harness on a 70 e body from under the dash? Or will I have to pull the whole dash out or apart. Just trying to plan everything out before jumping in. Thanks
Re: replacing e body dash harness? [Re: 440forPOWER] #1016228
06/19/11 12:47 PM
06/19/11 12:47 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
its best to pull the dash and do all the work. You'll break less pieces and be able to really do a neat/clean job if you work on it while on a bench and install the whole sub-assembly in one piece.
The good news for you is that I "think" that E-Body dashes come out w/o removing the windshield (not true for 68-70 B-Bodies)
Re: replacing e body dash harness? [Re: shanker] #1016229
06/19/11 01:01 PM
06/19/11 01:01 PM
NJ
Annie Offline
Annie  Offline
NJ
The cluster removed will give you needed access .But the advantage the E body has whole dash comes out with removing windshiled.While your in there check wiper pivot seals and maybe heater core
Re: replacing e body dash harness? [Re: Annie] #1016230
06/19/11 01:04 PM
06/19/11 01:04 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I did a dash restoration (in a 1991 Chevrolet truck) last year and its really best to do this on a bench...that way you can organize the harness like it needs to be, as well as route all the wires easily.
I cant stress how much easier it was with the dash out. Although I ended up swapping the entire dash out anyhow.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: replacing e body dash harness? [Re: shanker] #1016231
06/19/11 01:17 PM
06/19/11 01:17 PM
Lincoln NE
super gas
super gas
Lincoln NE
Ok, thanks. So do you have to remove the dash pad before you can take out the frame? Or is there any easier way to take it all out at once?
Re: replacing e body dash harness? [Re: 440forPOWER] #1016232
06/19/11 01:19 PM
06/19/11 01:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Removing the instrument cluster without scratching up the wood decal is the hardest part. The wiring is not that hard to remove once the cluster is out. Is it an A/C car? Those are harder
Drop the column, pull the cluster, remove ashtray, radio and glovebox. There's some built in straps that are hard to reattach when re-installing, but it's not that bad either way.
Take lots of close-up pictures as you disassemble, especially of how the wiring is routed around components etc.
It will be a good time to deal with the Amp Gauge Bypass and Wiring Bulkhead Issues when you are in there.
Re: replacing e body dash harness? [Re: jbc426] #1016233
06/19/11 02:14 PM
06/19/11 02:14 PM
Lincoln NE
super gas
super gas
Lincoln NE
Thanks, yes it's an ac car. The bulkhead and ammeter bypass has been done. But I was thinking of having the volt meter put in so I could hook it all back up right.
