Why oil coming out the dipstick tube hole at the block? *DELETED* #1015965
06/19/11 12:37 AM
06/19/11 12:37 AM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
Post deleted by Airgrabber
Re: Why oil coming out the dipstick tube hole at the block? [Re: Airgrabber] #1015966
06/19/11 12:41 AM
06/19/11 12:41 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
no O ring?
Mopar Performance
Re: Why oil coming out the dipstick tube hole at the block? [Re: moparniac] #1015967
06/19/11 01:05 AM
06/19/11 01:05 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Sounds like its slobbering pretty bad..... Blow By...
Re: Why oil coming out the dipstick tube hole at the block? [Re: Bob_Coomer] #1015968
06/19/11 01:20 AM
06/19/11 01:20 AM
Pewaukee, WI
Pewaukee, WI
What is the fix?
Re: Why oil coming out the dipstick tube hole at the block? [Re: Airgrabber] #1015969
06/19/11 01:27 AM
06/19/11 01:27 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What is the fix?
If it's blow by rebuild the engine, or go old school and put crank case vent tube on it
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Why oil coming out the dipstick tube hole at the block? [Re: Airgrabber] #1015970
06/19/11 03:15 AM
06/19/11 03:15 AM
Which motor, SB or BB,Hemi? If BB or 426 type Hemi maybe the dipstick tube is cracked at the pinch sealing ring where it is pushed into the block I've seen that cause leaks more than once
Re: Why oil coming out the dipstick tube hole at the block? [Re: Airgrabber] #1015971
06/19/11 03:52 AM
06/19/11 03:52 AM
NY
KillerB Offline
KillerB  Offline
NY
Might have a hairline crank at the base of dipstick, is the tube loose in the block or snug? Chrome or oem?
