wiring a 3 wire denso
#1015760
06/18/11 06:48 PM
06/18/11 06:48 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have a 130 amp 3 wire denso with the internal reg, how do i wire this. Bear in mind, i have done away with the plugs on the firewall and bypassed the ammeter. Can i run the hotwire direct to the starter relay.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: wiring a 3 wire denso
[Re: fourgearsavoy]
#1015763
06/19/11 07:13 PM
06/19/11 07:13 PM
deaks
robin hood country
Yes, it is that style, except it is 130 amp. I have fitted it today, power and sense wire to the large stud on the relay, ign to blue but can the lamp wire be used as power for a volt meter, also will a 40 amp fuse in the sense wire be big enough. Thanks Mick
[Re: deaks]
#1015764
06/22/11 05:04 PM
06/22/11 05:04 PM
Posts: 13 NY
KillerB
NY
Pretty sure when I wired mine, the lamp wire was not used , it's just for a dummy light. Just use a 12volt source for volt gauge. The sense wire I believe should be powered when the key is on otherwise the regulator charging circuit would have power all the time. It's been awhile, so don't quote me.
