Page 1 of 3 1 2 3
Critique my 340 build please ........ #101515
08/08/08 02:59 PM
08/08/08 02:59 PM
North Florida
RebelDart Offline OP
super street
super street
North Florida
The only machine shop in my vicinity aren't the most talkative bunch. I need some insight before we button this thing up. Any thoughts or concerns would be appreciated :
Bottom end:
68 340 .030 over
TRW L-2316 forged flat top w/ 8cc valve relief, .030 above deck (shouldn't be an issue from what I'm being told)
Stock rods w ARP's
Stock forged crank
Lunati 60403 @ .050 IN/EX: 226/234;Lift IN/EX: .494"/.513"
Worked X heads flow around 240 @ .050, 75 cc
With current head gasket I calculated 9.2:1 compression (not sure how to get more if needed)
Airgap and 670 Street Avenger
TTI headers
3500 stall
3:91 gear
Look okay ? I do have an objective eventually which would be mid-low 12's.
Thanks all.
Re: Critique my 340 build please ........ [Re: RebelDart] #101516
08/08/08 03:11 PM
08/08/08 03:11 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
If the pistons are .030 out of the hole I think your compression might be higher than you calculated. I think a 70 340 piston was .018 out of the hole and compression is rated over 10 to 1.
How big are the relief's in those pistons? Heads might be 72cc
Re: Critique my 340 build please ........ [Re: RebelDart] #101517
08/08/08 03:17 PM
08/08/08 03:17 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
You had better check your clearance between the cylinder head and the piston. I think you might have problems at the spark plug side of the chamber, also if the chambers are stock there is an eybrow shaped part of the casting around the intake valve that protrudes into the chamber that could hit. The final check of the clearance has always been to try and turn the engine over with no head gaskets in place, then if you use a ,040 gasket you will be in the ballpark. If your pistons are .030 down in the cylinder instead of .030 out you should be fine.
Re: Critique my 340 build please ........ [Re: rdrmod6] #101518
08/08/08 03:22 PM
08/08/08 03:22 PM
North Florida
super street
super street
North Florida
We will be checking ... pistons are .030 above. Chamber volume is 75cc. If all clears I'm happy except for compression being lower than I want (?)
Re: Critique my 340 build please ........ [Re: RebelDart] #101519
08/08/08 03:31 PM
08/08/08 03:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Sounds like a nice streetable combo.My experience is with 360 and larger small blocks,I don't see any problem with your plan.I'd consider having the heads milled to get the compression up a bit,if the chambers are really 75cc. What machine shop are you using?
Re: Critique my 340 build please ........ [Re: goldmember] #101520
08/08/08 03:36 PM
08/08/08 03:36 PM
North Florida
super street
super street
North Florida
Called Tachyon Performance - I get the sense I'm "bothering" them. Unless I'm dropping off something or picking up and handing them my Visa - you know. I'm trying to do as much myself as possible. Didn't know if I should shoot for higher compression or not for my goals - and don't know how I'd achieve with the current config (pistons out the top).
Re: Critique my 340 build please ........ [Re: RebelDart] #101521
08/08/08 03:38 PM
08/08/08 03:38 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Are you going to assemble it yourself?
Re: Critique my 340 build please ........ [Re: goldmember] #101522
08/08/08 03:47 PM
08/08/08 03:47 PM
North Florida
super street
super street
North Florida
If I can get up the nerve , I'd like to
Re: Critique my 340 build please ........ [Re: RebelDart] #101523
08/08/08 03:48 PM
08/08/08 03:48 PM
North Florida
super street
super street
North Florida
Or I can bring to G'ville and you can evaluate in person !
Re: Critique my 340 build please ........ [Re: RebelDart] #101524
08/08/08 05:22 PM
08/08/08 05:22 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Like said, Check the piston to head clearance. Its to tight. Compression could be better but could be worse. It should run hard.
Re: Critique my 340 build please ........ [Re: RebelDart] #101525
08/08/08 05:22 PM
08/08/08 05:22 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I would think you would want compression in the 9.5:1 range. Issue is piston to head clearance. Measure how deep the relief is in the head to get an idea of how thin a gasket you can use. Bolt it together and check piston to head clearance by removing rod cap at TDC and measuring how far up piston travels until it hits the head.
Then if that works out degree in cam and check piston to valve clearance.
Re: Critique my 340 build please ........ [Re: 69Cuda340S] #101526
08/08/08 05:26 PM
08/08/08 05:26 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
You can use some real soft clay on the piston and cycle it with the valves/cam installed to check clearance.
I run KB 243's .019 out of the hole and some stock J heads with a 284/284 MP cam
Re: Critique my 340 build please ........ [Re: RebelDart] #101527
08/08/08 07:01 PM
08/08/08 07:01 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
If you're using a head gasket with 0.039" compressed thickness, you should still have plenty of piston to head clearance with the iron heads.
IIRC, the chambers are about 0.100" or more deep.
I've got that same cam in my 340 and love it.
My pistons are 0.020" above the deck and I have plenty of piston to valve clearance. But the KB pistons have pretty generous valve reliefs.
That's the clearance you need to be concerned about.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Critique my 340 build please ........ [Re: RebelDart] #101528
08/08/08 07:23 PM
08/08/08 07:23 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
you might need more cam for mid to low 12's
Re: Critique my 340 build please ........ [Re: RebelDart] #101529
08/08/08 07:52 PM
08/08/08 07:52 PM
1st need ALL measurements: piston amt in/out of hole(deck height),amt(cc's) of piston dome, cc's of valve reliefs, CC's of heads,depth of open chamber recesses. So you can machine to achieve .035-040 quench & the CR you need(& 9.2 isn't enough) which will go with determining what head gasket you need & wondering what octane FUEL will you be useing? Thats too bad they are not being customer friendly but unfortunately that is all too common. Stay with it,you want this thing right.
Re: Critique my 340 build please ........ [Re: UCUDANT] #101530
08/08/08 08:26 PM
08/08/08 08:26 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
i'm not an engine wizzard by any means but this is what i was thinking half way throuh your post.
Re: Critique my 340 build please ........ [Re: west] #101531
08/08/08 09:42 PM
08/08/08 09:42 PM
North Florida
super street
super street
North Florida
I used one of the on-line calculators, pretty self explanatory - chambers cc'd by the shop @ 75cc's , valve reliefs are 7.5 cc's The calculators have a field for deck height and state to use a negative number for positive deck height, etc. I'm fairly certain I'm accurate in regards to these specs and using the calculator correctly. Any old-schoolers may have a different method.
Re: Critique my 340 build please ........ [Re: 340727dart] #101532
08/08/08 09:56 PM
08/08/08 09:56 PM
North Florida
super street
super street
North Florida
This is what we're supposing as well. The TRW's we're using L2316F)have a 7.5cc relief. If I have to shave - so be it, but I need the compression so not sure the best route to take.
Re: Critique my 340 build please ........ [Re: RebelDart] #101533
08/08/08 11:50 PM
08/08/08 11:50 PM
New Zealand
dart6 Offline
dart6  Offline
New Zealand
i get 9.362 cr with 4.070 bore and .039 gasket
Re: Critique my 340 build please ........ [Re: RebelDart] #101534
08/09/08 12:17 AM
08/09/08 12:17 AM
[quote The TRW's we're using L2316F)have a 7.5cc relief. If I have to shave - so be it, but I need the compression so not sure the best route to take.
You will be milling the heads & probably not the dome. this calculator is very nice. http://kb-silvolite.com/calc.php?
Page 1 of 3 1 2 3
