Bad rebuild burns up hemi. 241 dodge hemi. #1015131
06/17/11 02:37 PM
06/17/11 02:37 PM
God's Country PA
Magnus_Jager Offline OP
God's Country PA
Found the squeak the top side of the passenger side heads was bone dry no oil. Found the cause today. Shop installed the cam bearings wrong on number 4, pointed them towards the driver side, so no oil to the top on the passenger. Unfortunately it took me almost 5 years to get this far from the engine rebuild (which he ran over by 2 months on..)
Good news is I don't need a cam he did line up the bottom hole.. BUT I have to get a new gasket set, cam bearings, rocker assembly, for about $400... Just makes me sick to think about it. F'n attention to detail dammit.
Re: Bad rebuild burns up hemi. 241 dodge hemi. [Re: Magnus_Jager] #1015132
06/17/11 09:39 PM
06/17/11 09:39 PM
moparx Offline
moparx  Offline
boy that stinks ! attention to detail on any rebuild can make or break an otherwise great powerplant. hope you make out good on the refresh and don't find anything else that was neglected. for peace of mind, i would pull the engine and inspect the main & rod bearings closely as well as thoroughly clean the block to make sure none of the "squeeks" are "hiding" somewhere waiting to cause more damage.
Re: Bad rebuild burns up hemi. 241 dodge hemi. [Re: moparx] #1015133
06/17/11 11:33 PM
06/17/11 11:33 PM
God's Country PA
God's Country PA
Shouldn't have to check a "pro's" work...
Re: Bad rebuild burns up hemi. 241 dodge hemi. [Re: Magnus_Jager] #1015134
06/28/11 12:22 AM
06/28/11 12:22 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
u have to check every ones work these days,,,sorry to say,,,but if every one knew how to check there work,, we wouldnt need the so called pro,s.... i have big problems with a 241 red ram my self,,just cant get to it,,,hoping soon
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
