Factory seam sealing of engine bay? #1014722
06/16/11 11:38 PM
06/16/11 11:38 PM
SeventySatellite Offline OP
In what areas did the factory seam seal the engine bay?
Re: Factory seam sealing of engine bay? [Re: SeventySatellite] #1014723
06/16/11 11:53 PM
06/16/11 11:53 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
On my dart there was a blob of seam sealer at ea. corner where the cowl meets the fender aprons.
I stripped my engine compartment down to bare steel and other than those two spots at the top of the cowl I can't think of any other place that has any sealer.
Re: Factory seam sealing of engine bay? [Re: Neil] #1014724
06/17/11 08:36 AM
06/17/11 08:36 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I'm not real sure, but I think they might have put sealer between the top of the fenders where they bolt to the top of the inner fenders. Someone else might be able to varify this.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Factory seam sealing of engine bay? [Re: bobbyb] #1014725
06/17/11 02:02 PM
06/17/11 02:02 PM
I just remembered that there's a Mopar show I can go to next Saturday. I'll go ahead and check out the engine bays there.
Re: Factory seam sealing of engine bay? [Re: SeventySatellite] #1014726
06/17/11 05:08 PM
06/17/11 05:08 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The fenders had a sealer between the tops and inner fenders. Unless you see an original car or one redone correctly, most times they won't have it. I know on my own cars I skipped using it as I never drove them in the rain anyways. Some cars were pretty messy from the factory, others you don't see it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Factory seam sealing of engine bay? [Re: Silver70] #1014727
06/20/11 03:42 PM
06/20/11 03:42 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Seam sealer at horizontal fender joint.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014728
06/20/11 03:44 PM
06/20/11 03:44 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Seam sealer on underside of fender at horizontal joint. This sealer is tan and still soft.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014729
06/20/11 03:54 PM
06/20/11 03:54 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Welded seam at firewall to cowl joint had sealer oozing out. This sealer is painted. Also there is a black blob on this seam directly above the left side of the master cylinder put there after the body was painted. There is an identical unpainted blob on the passenger side also. Bonus: factory made an orange paint daub above the master cylinder.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014730
06/20/11 10:27 PM
06/20/11 10:27 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Sorry, I inspected the dark blobs closely and found they actually are painted - the paint just didn't adhere to the sealer well, but the paint is there. The firewall-to-cowl joint had sealer placed on the joint, then it was clamped and spot welded, causing sealer to ooze out. More photos later.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014731
06/21/11 11:50 PM
06/21/11 11:50 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Four blobs across the cowl seam. There are also two more in the front corners of the engine compartment where the inner fenders meet the radiator yoke to cover small holes in those joints.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014732
06/21/11 11:53 PM
06/21/11 11:53 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Intended blob at the passenger side, along with an unintended extra. Note that the hole in the corner isn't totally covered.
Re: Factory seam sealing of engine bay? [Re: kentj340] #1014733
07/06/11 11:51 PM
07/06/11 11:51 PM
New York, USA
Chargerfan68 Offline
New York, USA
On my 68, the welded seam had sealant in between also...however, I don't think it was seam sealer. It looks to be what our paint shops here call "hood Flutter". It is more foam like and has air holes inside when you break it apart. The stuff I bought for in between the hood skin and inner structure was a 2 part mixture in a gun and when applied, it expands and sets up pretty quickly.
this is the stuff I will use when I replace the upper/lower cowl area when welding them together.
Re: Factory seam sealing of engine bay? [Re: Neil] #1014734
07/07/11 09:45 AM
07/07/11 09:45 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Think the guy that did your Dart was on his second day while one of my old Demon's must have been his first. On the Pass. side cowl to fender area of this one Demon there was a giant blob of sealer, almost like the sealer gun got away from this guy and stuck in that blob were two nuts for the fender stud in the door jamb. All this mess was painted yellow with the rest of the car.
Re: Factory seam sealing of engine bay? [Re: rrunner] #1014735
07/07/11 10:51 AM
07/07/11 10:51 AM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
I found six (6) places where seam sealer was applied on my StL built 69 RR. I will post a picture of one side.
Picture #1
Re: Factory seam sealing of engine bay? [Re: 474218] #1014736
07/07/11 10:53 AM
07/07/11 10:53 AM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Picture #2
Re: Factory seam sealing of engine bay? [Re: 474218] #1014737
07/07/11 10:54 AM
07/07/11 10:54 AM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Picture #3
