Victor valve covers #1014315
06/16/11 01:48 PM
06/16/11 01:48 PM
Mo.
supercomp Offline OP
Mo.
Does anyone know of some valve covers that will work with Victor heads and T&D rockers without major surgery?
Re: Victor valve covers [Re: supercomp] #1014316
06/16/11 02:40 PM
06/16/11 02:40 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
Mopar performance black wrinkle finish cast allumvalve covers, works on my vic heads with t+d rockers w no problems very close i had to use the thick black valve cover gaskits.I like my eng so far with these heads went for a test drive the other day it pulled the wheels up 2ft with out warming up the tires.
Re: Victor valve covers [Re: hot67cuda] #1014317
06/16/11 05:33 PM
06/16/11 05:33 PM
Mo.
Mo.
Thanks, I appreciate it.
Re: Victor valve covers [Re: hot67cuda] #1014318
06/16/11 05:35 PM
06/16/11 05:35 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
on the street??
Mopar Performance
Re: Victor valve covers [Re: supercomp] #1014319
06/16/11 06:18 PM
06/16/11 06:18 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Do Victors need special valve covers in general? I saw a pic in the AndyF book that showed how a Moroso vc gasket didn't line up correctly on a Victor head and was wondering if that meant that some valve covers have the same problem.
Re: Victor valve covers [Re: PorkyPig] #1014320
06/16/11 07:16 PM
06/16/11 07:16 PM
AndyF Offline
AndyF  Offline
The Victor heads that I had were a little off on the valve cover rail. I talked to several other people who also had the same issue. I don't know if it was a casting problem for a while, or a design issue or what. But the valve cover rail on the Victor heads were not the same dimensions as either stock heads, or RPM heads.
