41 Plymouth Business coup / axle questions #1014240
06/16/11 10:43 AM
06/16/11 10:43 AM
Parsons (SouthEast) Kansas
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
Hey guys, JP in Parsons ks. I am buying a 41 ACP or ASC (?)coupe tomorrow. i refer to them as business coupes but it has jump seats instead of the cargo divider so i don't really know what it is. I ha ve a dakota chassis and good magnum 318/518 OD for it. What rear axles are you guys using? i am going to do the dak front clip but keep the stock rear frame sections. I've heard B/E body 8&3/4s are almost bolt-in. I can use a dak rear but i have sure grip third members laying around. I'll post pics soon. I'm getting it out of Oklahoma and was posted on HAMB. JP in the land of oz. 620-820-3793
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp] #1014241
06/16/11 11:20 AM
06/16/11 11:20 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The dakota clip is a bit wide for the car, you will end up with FWD offset wheels on the front to clear.
If you have read here and the HAMB, you know a lot of guys with these suggest the shock relocation, dropped spindle and disc conversion for savings and ease. If you gotta have a clipped car, they seem to be the most commonly sold as half-done projects...
I used a 68 Coronet wagon axle, changed the spring perches. I have heard the later model Explorers work.
Re: 41 Plymouth Business coup / axle questions [Re: RodStRace] #1014242
06/16/11 02:54 PM
06/16/11 02:54 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have an 88 dakota clip on my 47 desoto. the rear i got out of an 79 ramcharger, its an 9.25 355 gears w/ 4.5"bp and is the right width.
Re: 41 Plymouth Business coup / axle questions [Re: 65rbdodge] #1014243
06/16/11 06:30 PM
06/16/11 06:30 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp] #1014244
06/16/11 10:15 PM
06/16/11 10:15 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Used 68 Coronet 8 3/4 on the 36. Bolted right up, perches were right on. Used original springs, blasted and coated.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp] #1014245
07/05/11 01:42 AM
07/05/11 01:42 AM
Canada
CrAzYMoPaRGuY Offline
Canada
8 3/4 rear in my '40... bolts in perfectly.
Well, NOW it does.
CrAzYMoPaRGuY
