3.9 Magnum V-6 A-500 in early A-body
#101395
08/08/08 02:53 AM
08/08/08 02:53 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
Has anyone installed the 3.9 Magnum with A-500 trans in a '65 Dart or similar early a-body? A friend is contemplating this swap but would like to have an idea what problem areas to look for. TIA, Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: 3.9 Magnum V-6 A-500 in early A-body
[Re: MOBodyman]
#101396
08/08/08 07:53 AM
08/08/08 07:53 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
well.....
1) you're on your own for engine mounts, the 3.9 doesn't have ears like an LA, just the magnum style 3-bolt pad.
2) if planning to carb it, you're choices are either the early 2bbl carb/tbi intake or the unobtanium MP 4bbl.
3) depending on how far forward you mount it, you may have a lot of tranny tunnel/tbar xmember hacking and whacking to fit an A500.
might want to search hotroddave's "super duper 273/318 gas mileage" thread, he was getting some impressive mileage (low 20's city, upper 20's hwy) from a well thought out 318/904lockup/2.76 rear. if you want OD, I'd look at changing the 904/2.76 with an A833OD/2.94 or 3.23 combo.
[Re: patrick]
#101397
08/08/08 05:51 PM
08/08/08 05:51 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Patrick I can't find my own thread, is it still here?
[Re: HotRodDave]
#101398
08/08/08 07:34 PM
08/08/08 07:34 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Personally, If I were to do a non-v8 swap into one of these cars i'd go with the neon SRT-4 Turbo 2.4 with the liberty 2wd 5-speed manual trans OR the AX-15 out of a dakota. It does require more work than the 3.9, but the payoff is bigger, much more power and likely better fuel mileage.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: HotRodDave]
#101401
08/10/08 03:29 AM
08/10/08 03:29 AM
MOBodyman
Missouri
I appreciate the replies. Thanks, Dallas
[Re: MOBodyman]
#101402
08/10/08 07:53 AM
08/10/08 07:53 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I did a bit of preliminary research for this swap in my 65 Cuda.
If you were to mount the V6 so that the front of the block was in the same location as the V8 would have been then tunnel clearance for the A500 opens up alot.
However, I was never able to figure out if the oil pan would work with teh chassis. Didn't have any good dimensions to work from.
Of course adding a turbo, or two, to the V6 would fix the power problems and a nice Megasquirt setup would fix the factory computer problem.
Never got farther than that with it, no money for it.
