99 dodge ram miss #101366
08/07/08 11:44 PM
08/07/08 11:44 PM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
I have a 99 dodge 1500 318 motor auto trans w overdrive. i have a slight miss when sitting at an idle with a warm or cold engine. it also misses when the engine is lugged. but not when i open the throttle and get the rpms up. i have replaced plugs, wires, rotor, cap, idle control valve, and air cleaner. im outa ideas please help
Re: 99 dodge ram miss [Re: hubey] #101367
08/07/08 11:57 PM
08/07/08 11:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Codes?
Re: 99 dodge ram miss [Re: NITROUSN] #101368
08/08/08 12:00 AM
08/08/08 12:00 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
check engine light isnt on, could it have a code even though the light isnt on?
Re: 99 dodge ram miss [Re: hubey] #101369
08/08/08 12:16 AM
08/08/08 12:16 AM
N
NITROUSN Offline
NITROUSN  Offline
N
yes
Re: 99 dodge ram miss [Re: NITROUSN] #101370
08/08/08 12:20 AM
08/08/08 12:20 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
Ok, this might be a dumb question but how do i check for the codes? can i use the same code reader that i would use if the engine light was on?
Re: 99 dodge ram miss [Re: hubey] #101371
08/08/08 12:22 AM
08/08/08 12:22 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Miles on the truck and does it ping under load ?
Re: 99 dodge ram miss [Re: JohnRR] #101372
08/08/08 12:25 AM
08/08/08 12:25 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
99,500 miles and no ping.
Re: 99 dodge ram miss [Re: hubey] #101373
08/08/08 12:26 AM
08/08/08 12:26 AM
JohnRR Offline
JohnRR  Offline
last time for a tune up ?
Re: 99 dodge ram miss [Re: JohnRR] #101374
08/08/08 12:42 AM
08/08/08 12:42 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
i put plugs, wires, cap, rotor, changed oil and air cleaner, and put an idle control valve in last week. i got the good stuff too, none of it was bargain discount walmart stuff. that was all in effort to try to get rid of the miss.
Re: 99 dodge ram miss [Re: hubey] #101375
08/08/08 05:13 AM
08/08/08 05:13 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Battery and charging system checks out ok at idle?
Re: 99 dodge ram miss [Re: earlybee] #101376
08/08/08 06:52 AM
08/08/08 06:52 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
I have a simlar problem with my 99 p/u , but it not as bad! any info would be a big help.. Someone mention it might be a vacuum leak..
Re: 99 dodge ram miss [Re: BigTerry] #101377
08/08/08 08:14 AM
08/08/08 08:14 AM
JohnRR Offline
JohnRR  Offline
I was going to ask if he has had the intake plenum gasket changed , but no pinging kinda rules that out ???
Re: 99 dodge ram miss [Re: hubey] #101378
08/08/08 08:26 AM
08/08/08 08:26 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
it might be that the crankshaft position sensor (CKS)
is not picking up one of the notches on the flexplate
because the CKS is mounted just a few thousandths
to far out, or the plate is wobbling, etc
The CKS sensor is a pain to get to
so it might be worth using an oscilloscope
to monitor its electrical pulse train first
sometimes using an inductive pickup timing light
and clipping onto each cylinder in turn
will show which cylinder is the one missing
cylinders 7 and 8 in the back of Magnum engines
are prone to both head gasket and plenum gasket failure problems, plus their fuel injector baskets are 'first in line' on the fuel rail and fill with crud.
suspect them first
good luck
Re: 99 dodge ram miss [Re: earlybee] #101379
08/08/08 09:40 AM
08/08/08 09:40 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
charging system is working great, i thought bout a vacume leak too. as far as i can tell there isnt one at idle, i used a piece of gas line as a stethoscope and there was no hissing.
Re: 99 dodge ram miss [Re: 360view] #101380
08/08/08 09:46 AM
08/08/08 09:46 AM
Pennsylvania
hubey Offline OP
hubey  Offline OP
Pennsylvania
i never thought bout the CPS, one question though, was is an oscilloscope and where can i get one. i never thought bout the timing light either. well thanks for the ideas, its back to the garage.
Re: 99 dodge ram miss [Re: JohnRR] #101381
08/08/08 02:28 PM
08/08/08 02:28 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
Not necessarily, I just changed mine and it wasn't pinging, but it would hardly idle. Plug the pcv connection on the passenger side of the intake and pull the hose off the drives side valve cover that goes to the air filter. Start it up and see if that hose has a vacuum on it. Mine had a vacuum and it went away once I changed the plenum gasket. I had changed it before around 125,000 with the new improved Felpro gasket and it didn't hold either, so this time I used the Hughes plenum plate which is alot thicker than the factory piece.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
