Sending Unit - Best Place to Buy and Questions
#1013512
06/14/11 10:20 PM
06/14/11 10:20 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I am seeing a fairly significant range of prices. Looking for a sending unit for the Dart, 1/2" pickup.
Thanks.
I see there is an offering with a 1/4" return, but only offered in 3/8". The 1/4" return would be nice as I need a 1/4" return from the pressure regulator to help fight off vapor lock.
How do you guys typically handle this? Drill the sending unit or return into the fill tube somehow? The latter seems like it might not be a great idea... hmm.
Also, 1/2" may be overkill. I would guess 3/8" could supply lots of HP.
383, Hemi 4-Speed, AlterKtion, D60
Re: Sending Unit - Best Place to Buy and Questions
[Re: Kern Dog]
#1013515
06/15/11 07:29 AM
06/15/11 07:29 AM
Crazy68Dart
Canton, Ohio
Has the quality improved at all? I have read many times that people had exactly the same problems that I have....FULL tank, guage reads 5/8 to 3/4. Half tank, guage reads 1/4. 1/4 tank of fuel, guage rests on the E line. This is terrible.
Wow, after market piece with quality issues, there is a surprise.... not what I wanted to hear.
Anyone have any luck modifying the stock unit, removing the line, and replacing with larger?
[Re: stateroadhog]
#1013518
06/15/11 11:34 AM
06/15/11 11:34 AM
Posts: 416 Franklin Co. Illinois
runinonmt
bought mine from 521 resterations. Called and asked about calibration told me they were all checked to be accurate. Well same problem reads 3/4 when full, reads 1/2 with just 5 gals gone. Is there a fix for this?
If this continues to get worse I would suspect a sinking float. I also got mine from 521 Restorations. When I got mine I checked it myself. It was within factory spec. When finished I put in 2 1/2 Gals. of gas and drove to the station where I added 5 more. Read just under half full. Time to check up the line. A common problem is resistance or shorts in the connectors and wiring. Be sure the ground strap is properly connected to CLEAN metal. Check continuity from the sending unit wire to the back of the gauge. Also check for resistance to ground with the sender and gauge wires unhooked. A high resistance short here would make the gauge read high.The gauge cluster voltage regulator is usually either good or bad. If you'd like to reda more: http://www.allpar.com/history/mopar/electrical2.html Hope this is helpful Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: stateroadhog]
#1013522
06/15/11 10:06 PM
06/15/11 10:06 PM
Crazy68Dart
Canton, Ohio
The issue with a fuel gauge is that they are not linear. What needs to be accurate is when it is full (at least close), but more importantly when they are empty. I think between these points anything is "fair game". http://auto.howstuffworks.com/fuel-gauge.htm
[Re: Crazy68Dart]
#1013524
06/15/11 10:35 PM
06/15/11 10:35 PM
Posts: 7,664 IN
ahy
IN
The basic process for adding a larger pickup is to remove the old and drill out the hole a little undersize for the new tube. Then use a drift to enlarge the hole so it makes a small flange or raised area to grip the new tube tightly. Then solder in with a high power iron or torch. I've never done it... and don't plan to try but that is the basic approach.
[Re: Kern Dog]
#1013526
06/16/11 09:44 AM
06/16/11 09:44 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
Same here, new tank and unit.
[Re: DennisH ]
#1013527
06/16/11 01:53 PM
06/16/11 01:53 PM
Crazy68Dart
Canton, Ohio
Hmm, maybe I'll weld a sump to my brand new tank and use the 5/16" as the return off the original sending unit. At least I know the thing works, at least it did 9 years ago when I pulled the car apart.
[Re: DennisH ]
#1013528
06/16/11 02:37 PM
06/16/11 02:37 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Mine reads the same.
[Re: stateroadhog]
#1013531
06/16/11 08:38 PM
06/16/11 08:38 PM
RapidRobert
You've verified a good ground & I was thinking maybe a person could add a resistor in series to up the resistance to reduce voltge to shift the needle back to dead on E when the float is at the bottom of it's travel BUT w it's showing a diff reading each time I'd eyeball the windings & see what's changing/shorting as something is or there is a poor connection somewhere that is changing the ohms but you are physically moving the float/arm between tests so I'd zero in on the windings & check that the arm that slides on the windings has enough tension down on the windings or anything else that dont look kosher.
