Re: Leaf spring relocation and mini tubs
[Re: DemonKyle]
#101354
08/08/08 01:50 PM
08/08/08 01:50 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
RobX4406 just did a home mini tub and relocation kit. Maybe he'll chime in or you can pm him
No mini tubbed B bodies in my neighborhood...
You might post this on the race board. Probably get more responses.
[Re: Casey]
#101355
08/08/08 02:44 PM
08/08/08 02:44 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
It is fairly straight forward - need to be careful on cuts and you need to be good with welding/fabrication. I did a 70 Charger which should be identical. I have 17" of tire clearance. Given 1.5" of side wall clearance, you can easily run a tire 14" wide with room to spare. I'll be running 18x12 wheels on the back with LOTS of extra room. Here are some photos of what I did (based on www.bigblockdart.com as a guideline): Click on the first photo and there is wording/description as well. 70 Charger minitubs
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
