6 pack #1013413
06/14/11 07:12 PM
06/14/11 07:12 PM
mt
440_dup77 Offline OP
mt
What would make my car just stop when i floor it,seems to started when i took the rear carb off.But if i step on slowly, it seems to be ok.
Re: 6 pack [Re: 440_dup77] #1013414
06/14/11 07:33 PM
06/14/11 07:33 PM
vac leak. Take the carb back off & eyeball the base gasket and check the vacuum secondary diapram & carb internal gaskets. Go where you were b 4 when you were into the carb & look for a bad/torn/misassembled gasket etc
Re: 6 pack [Re: RapidRobert] #1013415
06/14/11 07:39 PM
06/14/11 07:39 PM
mt
mt
I checked the vac lines,they looked like they were all hooked up,will take carb off if i cant fine something else.
Re: 6 pack [Re: 440_dup77] #1013416
06/14/11 07:42 PM
06/14/11 07:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
RR was referring to the mounting gasket between the carb and manifold. start the car up and spray some carb cleaner around the base of the carb. if it surges then you have a a leak.
Re: 6 pack [Re: mikemee1331] #1013417
06/14/11 07:45 PM
06/14/11 07:45 PM
mt
mt
ok,will go out and do now,Was going to do that,but forgot.
Re: 6 pack [Re: 440_dup77] #1013418
06/14/11 07:56 PM
06/14/11 07:56 PM
mt
mt
Sprayed carb cleaner around carbs and vac lines, no leaks.
Re: 6 pack [Re: 440_dup77] #1013419
06/14/11 08:03 PM
06/14/11 08:03 PM
b 4 takeing the rear carb off it was OK when you floored it & nothing else was worked on/changed? What did you do to the carb?
Re: 6 pack [Re: 440_dup77] #1013420
06/14/11 08:05 PM
06/14/11 08:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what was the reason for pulling the carb? was it running fine before that? did you mess with the vac secondaries at all?
Re: 6 pack [Re: mikemee1331] #1013421
06/14/11 08:12 PM
06/14/11 08:12 PM
mt
mt
The fuel line was leaking had to take off carb,so i could get to the top nut.
Re: 6 pack [Re: 440_dup77] #1013422
06/14/11 08:15 PM
06/14/11 08:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Check your linkage,if the rods are tight,it will bind the throttle plates.At curb idle the rods should fit loose in the throttle shafts arms.
Re: 6 pack [Re: 62maxwgn] #1013423
06/14/11 08:20 PM
06/14/11 08:20 PM
mt
mt
Didnt touch the linkage or rods, Put everything back the way it was.Its like you just turn the key off.No warning.
Re: 6 pack [Re: 440_dup77] #1013424
06/14/11 08:27 PM
06/14/11 08:27 PM
That is a puzzler, sure sounds like a massive vac leak or something in the ign getting grounded by the linkage but I know that's a stretch. Now on a 6 pak only the center carb has an accel pump right?. Do check that it's still kicking out a healthy squirt & what speed are you at when you stomp it?
Re: 6 pack [Re: RapidRobert] #1013425
06/14/11 08:33 PM
06/14/11 08:33 PM
mt
mt
At dead stop.like i said,if i start off normal, its ok,just at standing start.
Re: 6 pack [Re: 440_dup77] #1013426
06/14/11 08:41 PM
06/14/11 08:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
could something have gotten into the fuel line? i would trace that back.
Re: 6 pack [Re: 440_dup77] #1013427
06/14/11 08:41 PM
06/14/11 08:41 PM
The front/rear carbs are vac operated right? Is there mechanical throttle linkage on the rear carb? if not (dont know 6 paks) the only connection from the rear carb to the rest of the system is the vac line to the pod is that correct? Might unhook/cap the vac line to isolate the rear carb EDIT & if it still dies & there is mech linkage opening the rear carb I'd disconnect the linkage & retry.
Re: 6 pack [Re: RapidRobert] #1013428
06/14/11 08:46 PM
06/14/11 08:46 PM
mt
mt
Front/rear are vac,linkage on rear,will work on it tomorrow.
Re: 6 pack [Re: 440_dup77] #1013429
06/14/11 09:45 PM
06/14/11 09:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
odd. seems like it would be a vacuum problem, maybe you got some junk in the rear carb? Maybe start from square one and re-tune it. Choke isn't sucking shut is it?
Coming soon!!!!
Re: 6 pack [Re: Mr.Yuck] #1013430
06/14/11 10:02 PM
06/14/11 10:02 PM
mt
mt
Guess will take it off, and start over.
Re: 6 pack [Re: 440_dup77] #1013431
06/14/11 10:07 PM
06/14/11 10:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't take them off, just grab your timing light and a vaccum gauge. unhook the ouboards and see how it runs.
