rearend oil #1013157
06/14/11 12:26 PM
06/14/11 12:26 PM
440dustr Offline OP
440dustr  Offline OP
What weight oil should I use in my 8-3/4 posi with 456 gears
Re: rearend oil [Re: 440dustr] #1013158
06/14/11 04:36 PM
06/14/11 04:36 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
75W-140 (GL-5) rated. Try it first (without) additional limited slip additive. If you experience chatter, then you need additional limited slip additive.
If you can get around not diluting the formulators blend with additives, you're better off as many find they don't require it.
