What weight oil should I use in my 8-3/4 posi with 456 gears
75W-140 (GL-5) rated. Try it first (without) additional limited slip additive. If you experience chatter, then you need additional limited slip additive.
If you can get around not diluting the formulators blend with additives, you're better off as many find they don't require it.
