I stock and sell both the Superformance and Fel Pro gaskets for this. The Superformance MP 15 material is good if you have a thick railed pan, or a good strong rigid pan. I have found the FelPro race gaskets much better in dual ( windage tray) type applications especially with a stamped steel style pan, which doesnt like to be overtightened.
RIP Monte Smith
