Re: R-12
[Re: TooMany62s]
#1012978
06/13/11 11:24 PM
06/13/11 11:24 PM
Posts: 7,664 IN
ahy
IN
If the system is otherwise OK... just down on refrigerant after many years I'd try to add the R12 first. I don't know what the current going rate is for a pound of R12, but I'll bet its a lot less than a conversion, done correctly, to newer refrigerant.
If you have significant problems that require completly emptying the system and replacing components, I'd go for the conversion.
I'm not an expert, but the simplest conversion requires draining and flushing the system to get all the old oil out, changing all O rings, changing the filter/dryer and changing the expansion valve. The original hoses, even though they may not be rated for the newer refrigerant should be OK.
The original condensor, in front of the radiator, may be marginal. For full performance a higher capacity condensor may be required (optional).
As I've learned, repairing/rebuilding AC systems isn't cheap so that's why trying a pound of R12 first may be a good idea.
Re: R-12
[Re: Paul_Fancsali]
#1012989
06/17/11 03:50 PM
06/17/11 03:50 PM
Posts: 1,012 indiana
mcmopars
indiana
1991 Caravantookout a/c box emptied system Put together and did nothing except charge system with R-134 that was pushing 4 years ago 90 degree's the other day and I had 41 degree air coming out of system You need some r-12 e mail me i just want to sell it Mopar cans to boot
i agree,fill and go.never had any issues
Re: R-12
[Re: mcmopars]
#1012990
06/17/11 07:10 PM
06/17/11 07:10 PM
Posts: 490 Boston Ma
Hamtramck
Boston Ma
Cans are available on e-bay from 15-20.00. Most sellers want a statement you will have a licenced tech install it.
69 roadrunner conv. 4spd B5/X9
