How do I test my clutch fan? #1012874
06/13/11 09:31 PM
06/13/11 09:31 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
Car got a little hot while idling in last week's heat and I figured one of the first hings to check would be the clutch on the fan. Sould it lock when idling, or lock when the engine gets hot. Not sure whether it works by heat or rpms. It is a 1970 Road Runner.
Re: How do I test my clutch fan? [Re: JeffRacerG] #1012875
06/13/11 10:46 PM
06/13/11 10:46 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I don't believe it ever actually locks up. Get it hot and running at idle then cut it off the fan should stop with in a few seconds or a few rounds. With the engine off but hot, spin the fan be hand, it should have a reasonably amount of resistance and it should only spin about 1-1.5 rounds when you spin it with some force. With the car off grab the fan and check the bearing for slack. If it fails any of these I would replace it.
Careful, your character's showing!
Re: How do I test my clutch fan? [Re: mopar346] #1012876
06/13/11 11:48 PM
06/13/11 11:48 PM
IN
ahy Offline
ahy  Offline
IN
A 1970 would likley have a "thermal" fan clutch. It has a little coil in front that senses temperature and tends to engage or "lock up" meaning it slips less when hot. If it fails the tests above, replacement is needed. My one experience with parts store clutches on a DD - torqflow brand - was not good and I went with OE. The MP re-pop setup from Mancini works well on my 1970E. The kit I used comes with a 5 blade "low drag" fan which worked fine in my application, however, with cooling problems I would go with the OE fan which is usually bigger/more aggressive or an even bigger fan like the 7 blade used on mid/late 70's BB Chrysler's (JY) or the 6 blade fan from Bouchillon.
Re: How do I test my clutch fan? [Re: ahy] #1012877
06/14/11 01:00 AM
06/14/11 01:00 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
While the engine is off, grab a fan blade at the 12:00 position and hold it firmly. Have someone start the engine (while you are still holding the fan blade and keeping it from turning) and take the engine to 2,000 rpm's and hold it steady. Let go of the fan blade and the fan and clutch should catch up to the 2,000 rpm's within a few seconds. If it does not - then it's not working correctly.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: How do I test my clutch fan? [Re: WyleECoyote] #1012878
06/14/11 01:32 AM
06/14/11 01:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
........oops forgot I don't have a clutch fan
Re: How do I test my clutch fan? [Re: WyleECoyote] #1012879
06/14/11 09:07 AM
06/14/11 09:07 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
While the engine is off, grab a fan blade at the 12:00 position and hold it firmly. Have someone start the engine... and take the engine to 2,000 rpm's...
Ummm. You hold it and I'll start it....
Re: How do I test my clutch fan? [Re: WyleECoyote] #1012880
06/14/11 10:57 AM
06/14/11 10:57 AM
scratchnfotraction Offline
wyleE is this the ACME clutch fan tester!!
hold fan while car flips over a few times
Re: How do I test my clutch fan? [Re: JeffRacerG] #1012881
06/14/11 05:39 PM
06/14/11 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When it comes to fan clutches the factory says the only way to test a unit is to replace it with a known good unit.....I totally agree.
Re: How do I test my clutch fan? [Re: WyleECoyote] #1012882
06/14/11 06:01 PM
06/14/11 06:01 PM
Poland
W
willard Offline
willard  Offline
W
Poland
If I did that with my fan, I'd probably lose a few fingers. My fan clutch seized and acted like a solid spacer.
Re: How do I test my clutch fan? [Re: willard] #1012883
06/14/11 06:36 PM
06/14/11 06:36 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i tried that with my lawn mower,once,once
Re: How do I test my clutch fan? [Re: mcmopars] #1012884
06/14/11 07:20 PM
06/14/11 07:20 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
I got bit by my lawn shark (lawn mower). Now got two less toes to show for it. Makes counting to 20 a real challenge . My friends call me Kunte Kinte !
Re: How do I test my clutch fan? [Re: JeffRacerG] #1012885
06/14/11 07:26 PM
06/14/11 07:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I can hear mine working, like when I get off the hi-way and come to a stop. Then when I take off I can hear the sound of my fan, it's louder. Then as it cools off the fan get's quiet again.
I have had 2 car's over the years that overheated at slow speeds or idle, both times new fan clutches fixed my problem and I could hear the fan again when it was hot. I have a 7 blade stock fans.
Re: How do I test my clutch fan? [Re: willard] #1012886
06/14/11 10:49 PM
06/14/11 10:49 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Okay - STEP 1 - Make sure clutch fan isn't seized and is free turning (see schematic).....
Wile E. Coyote
Re: How do I test my clutch fan? [Re: WyleECoyote] #1012887
06/15/11 11:23 AM
06/15/11 11:23 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Well Ron with your screen name's history can you really blame us for questioning that procedure you posted with that one small forgotten detail.. but Wiley always does that too
Can I hold it with something else besides my hand/fingers; like maybe a broom stick for now?
MikeR
Re: How do I test my clutch fan? [Re: Commando1] #1012888
06/15/11 12:10 PM
06/15/11 12:10 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
no you hold it and I'll start it
logan426
Re: How do I test my clutch fan? [Re: MLR426] #1012889
06/15/11 12:56 PM
06/15/11 12:56 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
That's nothing. You should see how he tests a high speed vibration.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: How do I test my clutch fan? [Re: HitIt] #1012890
06/15/11 03:48 PM
06/15/11 03:48 PM
ACME is the #1 mail order company
you mean they have a high speed vibration tester too?
Re: How do I test my clutch fan? [Re: JeffRacerG] #1012891
06/17/11 10:23 AM
06/17/11 10:23 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
back to the OP
consider using an electric heat gun
and for the other lower temperature extreme
'Quick Freeze' spray cans
to make the bi-metallic coil
lock or unlock
compressed air expanding through a
'blow gun nozzle' will also be cooler than normal outside air
with these two ways of heating or cooling the fan clutch,
and a non-contact infrared temperature meter
I would guess you could find the lock and unlock temperatures
On a 1995 360 Magnum V8 the Dodge Field Service manual says the lock temperature is approximately 220 degrees F,
which is also where the nominal 195 degree factory Stant 'Regular Grade' thermostat with steel body and brass underarms is supposed to be fully open. 195 degrees is where that factory thermostat is supposed to just start opening.
Re: How do I test my clutch fan? [Re: 360view] #1012892
06/18/11 09:53 AM
06/18/11 09:53 AM
New Jersey, USA
New Jersey, USA
The parts book (computer) at work shows both thermal and non-thermal. Is either one better than the other and which one should I get?
