Page 1 of 4 1 2 3 4
The good and BAD things the Ma MoPar engineers did .... #1012587
06/13/11 12:02 PM
06/13/11 12:02 PM
Florida STAYcation
dOOc Offline OP
The village idiot's idiot
dOOc  Offline OP
Florida STAYcation
Just from recent experiences ..... GOOD .... serp belts and those SLICK tensioners ....
The BAD ? ... the way they positioned the water-pump on a 3.3/3.8 motor on a 2003 Caravan. THEN the way they jammed it up next to the frame ....the LEAST they could have done is "punch" the frame for the ease of R&R.
Yurrrr thoughts ?
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOOc] #1012588
06/13/11 12:22 PM
06/13/11 12:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'm sure it ticked you off some, but just about all mfgs have built stuff that has made me say *@&%$# on occasion.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOOc] #1012589
06/13/11 01:22 PM
06/13/11 01:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd have to say the redesign of the Dodge Ram from 94 on up,....piss poor suspension design, horrible engine placement/accesss, canal water sucking transmissions, bad brakelines and gas tank straps,....suck ar$e water pump/clutch fan set-up, about the only thing they did get right was building a "good looking" truck......everything else mechanicaly was FUBAR
Re: The good and BAD things the Ma MoPar engineers did .... [Re: DAYCLONA] #1012590
06/13/11 05:33 PM
06/13/11 05:33 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Having to pull the ENTIRE dash out to replace the evaporator in a '93 Caravan. The designers probably figured the car would be dead long before the evaporator.
John
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOOc] #1012591
06/13/11 05:48 PM
06/13/11 05:48 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
In the last few years some Genius came up with the idea that when the cruise is set and you go DOWN a hill your fresh new Mopar will downshift to slow it down. Revving the pee out of the engine, killing fuel mileage, and surprising the crap out of everyone, this most fun feature is very usefull for when a loaded 18-wheeler is behind you.
The Engineer that thought of this was the Kid you went tobogganing/bicycling with and dragged his feet down the hill while bawling for his Mommy.
Reward offered to the tuning company that can bypass this counter-productive "safety feature".
Mo' Farts
Moderated by "tbagger".
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Grizzly] #1012592
06/13/11 06:09 PM
06/13/11 06:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's set at 70 it will still be going 70 so what's the big deal?
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOOc] #1012593
06/14/11 12:12 AM
06/14/11 12:12 AM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Great vehicle design! BUT its poorly executed...
My last recent Mopar was a 2000 Grand Cherokee Ltd. with 4.7 V8. Loved the truck! Great design, good engine, very torquey especially with the 3.73 rear end. The HVAC system just sucked. I think I replaced just about every component in that system. Finally got rid of it in 08.
In general what I've noticed about Chrysler from back in the day to the present; at lot of the trim tabs and features that hold things together, inside and out, never last. Initial quality might be good, but the damn thing falls apart just after the warranty is up.
It is that which holds me back from buying a new Challenger...
1972 Dodge Challenger
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Grizzly] #1012594
06/14/11 12:20 AM
06/14/11 12:20 AM
IN
ahy Offline
ahy  Offline
IN
Smokies often set up on downhill slopes - that feature has saved me a ticket or two...
Re: The good and BAD things the Ma MoPar engineers did .... [Re: PLUM_72] #1012595
06/14/11 12:24 AM
06/14/11 12:24 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
i am not digging the guy that came up with the great idea of "gluing" the windows in the regulator track of the 90's grand cherokees'.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: superbyrd] #1012596
06/14/11 12:29 AM
06/14/11 12:29 AM
IN
ahy Offline
ahy  Offline
IN
60's and 70's wiring that "sailed too close to the wind" in loads for individal wires and especially the bulkhead connector. Not too hard to fix now but a bad idea at the time.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: ahy] #1012597
06/14/11 12:52 AM
06/14/11 12:52 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Although I understand the advantages of "Rear Steer" steering linkage and the torsion bar suspension, these features DO play hell with header fitment.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOOc] #1012598
06/14/11 01:26 AM
06/14/11 01:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Compared to many other car brands, I'd say Mopar stuff was better designed and easier to work on.
I don't know about the 2003 caravan, but the water pump on my 1999 Carvan was very easy to replace. I did install the Gates belt/idler/tensioner kit that replaces the tensioner and idler with groved pulleys, and the belt is groved on both sides so it can't slip off.
Replacing the waterpump on a Pontiac Grand-Am with the quad4 is a real pain. It's chain driven, I think off of the timing chain, mounted next to the firewall, bolts to the block, timing cover and thermostat.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 451Mopar] #1012599
06/14/11 01:31 AM
06/14/11 01:31 AM
OK
70SWGR Offline
70SWGR  Offline
OK
4" boltpattern on a-bodies
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 70SWGR] #1012600
06/14/11 12:35 PM
06/14/11 12:35 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Bad-/6, sb and bb unmachined valve cover rail on head
Stupid-have to remove cam gears to remove rear timing cover to change water pump on 2.0/2.4 dohc and there is very little room between the gears and the inner fender.
good-dry intake, easy oil pump R&R, front distributor and simple water pump replacement on big block.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 446acuda] #1012601
06/14/11 02:18 PM
06/14/11 02:18 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
6 lug wheels on Dakotas!!!
Parts interchange: For instance, a master cyl. from a 79 Magnum will fit on a 94 Dakota for instance But parts books say they won't
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Magnumguy] #1012602
06/14/11 02:51 PM
06/14/11 02:51 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
good -- stuck with the tried and true 318 and 360 for what...40 years?! sure it got upgrades like EFI, but in whole, it's the same motor.
bad -- amp meters in the dash, taking the full load of the alternator through the wire harness, bulk head connectors, to the gauge, back to the wire harness, bulk head connectors and out to the battery.
**Photobucket sucks**
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 70Cuda383] #1012603
06/14/11 05:04 PM
06/14/11 05:04 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
good: The Mopar big block,with the external mounted oil pump,front mounted distributor,and 4 bolt water pump. A very easy engine to work on and maintain.
bad: The exhaust mainfold bolts going into the water jacket on the cylinder heads. With stock manifolds,the studs almost always come out with the nuts when removing them to change gaskets. With Headders the studs need to be removed to install them. This always causes a big coolant mess every time that the bolts are removed.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 70Cuda383] #1012604
06/14/11 06:19 PM
06/14/11 06:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They did correct the amp gauge problem around 1971 as they went to a shunt type amp gauge so the amp gauge only carried a small amount of the current. But probably not as accurate. Ron
Re: The good and BAD things the Ma MoPar engineers did .... [Re: PLUM_72] #1012605
06/14/11 07:05 PM
06/14/11 07:05 PM
NY NY
3
340duster340 Offline
NY NY
.. also good call on the chally..my dad bought an 09 srt8 new and it looks like it was painted outside. my brothers jeep liberty .. the interior pretty much self destructed, and my moms jeep grand cherokee ac box had and still has all kinds of problems.
MY favorite blunder were the mini vans that had the fan controller on the frame rail...eventually they would go bad from being exposed to the elements and the elec fan would stop, then it was a matter of time before a tank on the radiator blew. when i was working in a shop a changed a bunch all had the same issue.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 340duster340] #1012606
06/14/11 07:54 PM
06/14/11 07:54 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
How about having to remove the front bumper cover to replace a headlamp bulb on a Concord.
Page 1 of 4 1 2 3 4
