1994 Shadow Error Codes #1012496
06/13/11 09:11 AM
06/13/11 09:11 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
My sons 1994 Dodge Shadow (2.5L) started idling rough and stalling. We checked for error codes and got 12-25-55 so a code 25 was shown. I have no idea what the code means and the car completely stalled this morning and will not re fire?
Does anyone know what a code 25 is?
Re: 1994 Shadow Error Codes [Re: cl440] #1012497
06/13/11 09:19 AM
06/13/11 09:19 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Try this link.
http://minimopar.knizefamily.net/fault/code25.html
Code 25 looks like Idle speed problem could be vacume leak or electrical.
Re: 1994 Shadow Error Codes [Re: DodgeCharger] #1012498
06/14/11 12:07 AM
06/14/11 12:07 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
code 25 is coolant temp sensor code-next to t-stat-did you unplug it for any reason?disconnect neg cable about 10 minutes and run to see if it resets-rick
Re: 1994 Shadow Error Codes [Re: rbkt65] #1012499
06/14/11 09:07 AM
06/14/11 09:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the sensor fails it usually goes to mius 40 and is like running with a full choke on.Dosent take long to foul plugs.For the price change it and disconnect the battery.Pull plugs and see what they look like.Those were also known for the plate for the pickup in the dist coming apart.Pull the inspection plug on the belt cover and make sure the timing belt is OK.Rocky
Chrysler Firepower
Re: 1994 Shadow Error Codes [Re: rbkt65] #1012500
06/14/11 05:22 PM
06/14/11 05:22 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
25 is NOT the coolent sensor.
Re: 1994 Shadow Error Codes [Re: gdonovan] #1012501
06/14/11 09:16 PM
06/14/11 09:16 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
alldata says code 25 is ect-possible causes-sensor,wiring or pcm-this is from tha alldata tc chart
