automatic transmission fluid????????? #101169
08/07/08 04:47 PM
08/07/08 04:47 PM
Texas
missu34 Offline OP
missu34  Offline OP
Texas
what transmission fluid should I be using in my 727 torqueflight???
Re: automatic transmission fluid????????? [Re: missu34] #101170
08/07/08 07:45 PM
08/07/08 07:45 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
dextron II read the labels, they will tell you if it is recomm ended.
Re: automatic transmission fluid????????? [Re: satgtx] #101171
08/07/08 07:55 PM
08/07/08 07:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can use the Mopar ATF-4 in any Mopar auto trans and it is good fluid. Ron
Re: automatic transmission fluid????????? [Re: missu34] #101172
08/07/08 09:58 PM
08/07/08 09:58 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ford Type F if you can find it.
Re: automatic transmission fluid????????? [Re: 62maxwgn] #101173
08/07/08 10:02 PM
08/07/08 10:02 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Roger that with the F-type .... it improves HP shift quality.
Re: automatic transmission fluid????????? [Re: missu34] #101174
08/07/08 11:03 PM
08/07/08 11:03 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I'm using Type F, on the advice of my trans. builder...
Re: automatic transmission fluid????????? [Re: 318 Stroker] #101175
08/09/08 12:42 AM
08/09/08 12:42 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Another vote for type F, but only if you are starting with a fresh trans, the Dextron and type F fluids dont play well together and unless the trans is fresh there is a couple of quarts in the convertor and valve body that will be the old stuff.
Re: automatic transmission fluid????????? [Re: sthemi] #101176
08/09/08 05:43 PM
08/09/08 05:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
My personal favorite brew is a 50/50 mix of Dexron and type F. They play quite well together.
Re: automatic transmission fluid????????? [Re: John_Kunkel] #101177
08/10/08 04:17 PM
08/10/08 04:17 PM
Texas
missu34 Offline OP
missu34  Offline OP
Texas
the trans has not been serviced in a long time... so I plan to flush and refill.... it is not a new or fresh rebuild.
