Rear Wheel Stud Town and County,,,HELP
#1011410
06/12/11 12:21 AM
06/12/11 12:21 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Replacing a rear wheel stud on the wife's minivan. 2005 . Have replaced wheel studs before,,eg, on my Charger,,,and the Belvedere,,etc.
Got the old stud out,,,,
but there is NO room to fit the stud "behind" the hub,,,to pull it thru the hub
Do i need to pull the hub/axle on this ? ( if so,,,what are the steps to this,,,does the speed sensor need to be removed,,)
arrgghhh,,going to send the wife a bill on this one...lol
There is no access hole on the backing plate,,
thanks for any comments
Re: Rear Wheel Stud Town and County,,,HELP
[Re: 69CHARGERMD]
#1011411
06/12/11 09:49 AM
06/12/11 09:49 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Doug can you trim a little off the stud and still be safe? As long as you have a few threads outside the nut take some off and see what happens On a Toyota if you have to remove the rear hub/flange assy. you cant reuse it because damages the ABS sensor but I don't know if Mopar hubs seize in the beam like Toyota hubs do Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: teflon]
#1011414
06/12/11 12:21 PM
06/12/11 12:21 PM
69CHARGERMD
KENTUCKY
Thanks guys, I was able to slide it in, replacement stud was too long, got it in, good to go, thanks
