Re: Help me get an air pocket out of cooling system
[Re: Chris'sBarracuda]
#1011218
06/11/11 08:43 PM
06/11/11 08:43 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Get a radiator pressure tester,pressurize it at 20-25 lbs for 24 hours. That is about the best way I have found to get all the air out. If you don't have one you can get one from Autozone on their loan a tool program.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1011220
06/11/11 08:54 PM
06/11/11 08:54 PM
Guitar Jones
My Mezzaire will do this too. I just remove the top left side small allen head bolt from the pump that holds it to the pump housing, it bleeds out and then it picks up the water.
[Re: Guitar Jones]
#1011221
06/11/11 08:58 PM
06/11/11 08:58 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
LONG AGO I TAPPED A BLEEDER SCREW INTO THE VERY TOP OF THE PUMP HOUSING
home of the Sox and Martin Hemi Duster
[Re: Aspen7695]
#1011227
06/12/11 09:53 PM
06/12/11 09:53 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
did you check the rotation of the pump blades ?you might hear spinning backwards .or your pos neg is reversed also seen that happen . I would think air trys to raise why would the back of car HELP jack up front . let us alll know i've run a miesiere for 11 years sent in winter to freshen up . Don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: Aspen7695]
#1011229
06/13/11 06:56 AM
06/13/11 06:56 AM
Guitar Jones
Well,I replied too soon. I went out and fired the car up an hour ago and the same thing,no water flow. I jacked the rear end up as high as I could and let the pump run for two minutes. Lowered it back down and let it sit. I just tried it again and no flow.
Everytime I shut the pump off I hear a burping sound like water is filling up a void. I guess I'll start bleeding it again in hopes that it will eventually work.
Raul
Is your fill point lower than the intake? If so you may need a remote fill point like on the intake. Lots of OEM's have the radiator lower than the highest part of the engine so they use a remote fill and a bleeder on the engine.
