Motor Mounts #1011056
06/11/11 03:06 PM
06/11/11 03:06 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Doing Motor mounts on my 360 small block e-body
anyone ever do this? easy side walk job? or more involved
Tips and tricks and advice?
can I do one at a time no lifting engine out of car?
Suprised its not in the repair manual
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Motor Mounts [Re: Caparco] #1011057
06/11/11 11:19 PM
06/11/11 11:19 PM
Use a hyd bottle jack on one side at a time up against the oil pan bolts on the side of the eng to take the load off so You can R&R each mt
Re: Motor Mounts [Re: RapidRobert] #1011058
06/12/11 10:27 AM
06/12/11 10:27 AM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
cool.. any others?
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Motor Mounts [Re: Caparco] #1011059
06/12/11 12:10 PM
06/12/11 12:10 PM
scratchnfotraction Offline
I have use a cherry picker to lift the front of engine with a chain on the 2 front intake bolts
lift engine 1x and change both mounts let it down
watch the exhast pipes or headers when lifting so it wont tweek anything,but very do-able in an afternoon
Re: Motor Mounts [Re: RapidRobert] #1011060
06/12/11 12:38 PM
06/12/11 12:38 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i use basically the same thing. my floor jack and a piece of wood between the jack and the pan edge. i span across a couple of bolts to spread the weight.
