I'm installing a 6.1 hemi in an E-body. I used a car engine (both hoses are on the pass side), and using a 26" aluminum radiator with the hose connections on also on the pass side. I already tried 3-4 different hoses from the local auto parts store without any luck. If anyone has done a similar swap, I would like to know what hoses were used (part number or application)? Thanks in advance.
